  3. reading sens1 values from dcOpSens is very slow
  • Views 14908
Marcel Preda
Marcel Preda over 8 years ago
Hi *,
I'm trying to read some data from a dc sensitivity analysis.
For now I have two nested foreach loops something like
foreach(refSig refSigList
   foreach(instName instDataTable
      // some code
       sensVal = getData(strcat("sens1:" refSigSim "," instName ":dc") ?result "dcOpSens")
      // some code
But it is very slow, for 2 X 1838 combinations it takes ~22seconds shown in profiler. And most of it > 21seconds is spent in getData().
Is there other faster method to get this data?
What I've noticed is that from VIVA results browser if I'm generating the table with all signals and associated values it is much faster , less than 14 seconds.
Best Regards,
Marcel
    Hi Marcel,
    I'm not sure this will be any quicker, but I'd do it as follows:
    selectResult('dcOpSens)
    dataType=car(dataTypes()) ; probably just "sens1Req")
    foreach(output outputParams(dataType)
      pv("sens1" output)
    However, this seems fairly slow for me too, and I only have a tiny example (that said, there were 1135 outputs in my case and it was less than a couple of seconds). You probably will need to contact customer support. Unfortunately PSF is not fantastic for the case when you have a lot of such scalar values - so it may need work to update the result format to better handle this, or it might be possible with some further code optimisation on our side.
  • Marcel Preda
    Marcel Preda over 8 years ago in reply to Andrew Beckett
    It is perfect for now: run-time decreased 3 times.
    I have to run it on a bigger testcase.
    Best Regards,
    Marcel
