  3. how to automatically select the content of a field when...
  • Replies 8
  • Views 19257
how to automatically select the content of a field when a form appears?
iDave
iDave over 8 years ago
Hi all,
 I have create a form using hiCreateAppForm(), and when the form was invoked, the cursor will automatically focus on the first editable field, but will not select the content of that field.
I want to make the select automatically, so I can change the content directly by using keyboard. Is there any ways to implement it?
Another question: Is there any ways to remove the “Help” button from the form?
Dave
    I think if you just set the field with hiSetCurrentField:
    hiSetCurrentField(myform 'f1)
    Then it makes that the focus field, but also selects the content when it's displayed. Just to double check, which IC subversion are you using (Help->About in the CIW will tell you)?
  • iDave
    iDave over 8 years ago in reply to Andrew Beckett
    Thanks Andrew,
     I’m using the IC617isr15, And I have tried the function hiSetCurrentField(), but it seems doesn’t work well at all times . Below is my major script, could you please help me to find the problem, thanks!
    procedure(myDisplayForm()
        one = hiCreateIntField(?name ‘one
            ?prompt “test number”
            ?value 1)
      ;two = ...
        hiCreateAppForm(?name ‘myForm
            ?prompt “My Form”
            ?fields list(one)
            ?button ‘OKCancel)
        hiDisplayForm(myForm)
        hiSetCurrentField(myForm ‘one)
    Type in myDisplayForm() in CIW.
    Dave
    Andrew Beckett over 8 years ago in reply to iDave
    The code didn't quite work because the arguments to hiCreateAppForm are incorrect. I tried a number of things, and I think you can't do it when the form is created. You can however do it on subsequent calls to hiDisplayForm - so if you're displaying an existing form which is not being recreated.
    I tried using hiInstantiateForm beforehand, setting hiSetCurrentField before displaying the form (it makes no sense to do it after the display as you have, since hiDisplayForm will block by default). I even tried enqueueing the commands and adding a display, cancel and re-display to see if that helped (it didn't).
        one = hiCreateIntField(?name 'one
            ?prompt "test number"
            ?value 1)
      ;two = ...
        hiCreateAppForm(?name 'myForm
            ?formTitle "My Form"
            ?fields list(one)
            ?buttonLayout 'OKCancel)
        hiSetCurrentField(myForm 'one)
        hiEnqueueCmd("hiDisplayForm(myForm)")
        hiEnqueueCmd("hiFormCancel(myForm)")
    So you probably will need to contact customer support and ask for an enhancement to support this.
    On subsequent calls, I can just do:
    and then it seems to work (actually the set current field isn't really needed, since I only have one field).
    I didn't answer your other question in your original post about not having the Help button. I don't think you can remove it, but you could add:
       ?buttonDisabled list('Help))
    to the hiCreateAppForm call. This will at least grey out the Help button.
  • iDave
    Thanks a lot for your kindly response and what you did.
    I tried to use the subsequent calls as you said, and it works. But since I integrated the form to a pulldown menu, it meet another problem.
    Assuming  I have opened two layout cell which named layoutA and layoutB, and launch a form in LayoutA, then I get a formA, Now launch a form in layoutB, my desire is get a formB that is different from formA, but actually the shown form is still formA. How can I get a new form for every different layout cell?
    Let me show you the complete code.
    procedure(myDisqplayForm()
    let((one two)
           ?prompt "first number"
           ?value 1)
     two = hiCreateFloatField(?name ‘two
           ?prompt “second number”
           ?value 1.5)
           ?fields list(one two)
           ?callback “println(cv) printf(“%n %n\n” myForm->one->value myForm->two->value))
           ?mapCB   “cv=hiGetEditCellView()”
    myForm
    myDisqplayForm()
    procedure(myMenu(args)
       let((cw menu1)
            cw=hiGetCurrentWindow()
          menu1=hiCreateMenuItem(
                ?name ‘menu1
                ?itemText “menu A”
                ?callback “hiDisplayForm(myForm)”)
        allMenuID=hiCreatePulldownMenu(
              ‘allMenuID
                “All Menu”
                list(menu1))
        hiInsertBannerMenu(cw allMenuID 0)
          list(menu1) ))
    deRegUserTriggers(“maskLayout” nil ‘myMenu)
    Looking  forward to your reply.
    Dave
    Dave,
    I altered the code a bit to show how to do it:
    procedure(myCreateForm(lib cell view)
       let((one two myForm)
             ?value 1
          two = hiCreateFloatField(?name 'two
             ?prompt "second number"
             ?value 1.5
          ; create a unique form per cellView
          hiCreateAppForm(?name concat('myForm lib cell view)
             ?callback "println(hiGetCurrentForm()->cv) printf(\"%n %n\n\" hiGetCurrentForm()->one->value hiGetCurrentForm()->two->value)"
       myForm
    procedure(myDisplayForm(@optional (cv geGetEditCellView()))
       let((myFormName myForm)
           myFormName=concat('myForm cv->libName cv->cellName cv->viewName)
           myForm=symeval(myFormName)
           ; store the cellView id on the form to make it easier to obtain in
           ; the callback (i.e. it's set when the form is displayed, not when
           ; callback is invoked).
           myForm->cv=cv
       let((menu1 myFormName)
          myFormName=concat('myForm args->libName args->cellName args->viewName)
          unless(boundp(myFormName)
             myCreateForm(args->libName args->cellName args->viewName)
                ?name 'menu1
                ?itemText "menu A"
                ?callback "myDisplayForm()"
              'allMenuID
              "All Menu"
              list(menu1)
          ; do not insert the banner menu - return a list of
          ; menus
          ;hiInsertBannerMenu(cw allMenuID 0)
          list(allMenuID)
    deRegUserTriggers("maskLayout" nil 'myMenu)
  • iDave
    Thank you, Andrew.
     I will test the code at next Monday, have a  nice weekend to you.
  • iDave
     Thanks for your help. I have tested the code, and it solve my problem.
     But I have a query about the function “hiInserBannerMenu()”, why we shouldn’t use this  command to insert menu? Does “deRegUserTriggers()” insert myMenu automatically at the last position of banner menu?
    And my another question is how to close the user-defined form together when we close the layout window? I find after the layout close, the form that I created is still here.
    The whole point of the banner menu is that you return a list of banner menus for the Design Editor infrastructure to take care of adding into the banners. That way it knows about them and when you switch application they will get removed too. If you try to add them yourself (most commonly I see people doing this through the user post-install trigger) it can sometimes cause trouble with other applications that can end up fighting with  you!
    For closing the form (assuming you just mean to close it rather than delete the form data structure), you could register a close proc with hiRegCloseProc (probably from within a post-install trigger registered with deRegUserTriggers) which could then call hiFormCancel. If you wanted to delete the form, then you would be best served to register a trigger with dbRegPurgeTrigger which does an hiCancelForm, an hiFormDelete, and then sets the value of the form symbol to 'unbound. I probably wouldn't bother though because I doubt you'll end up with that many that it's worth cleaning up this way - but if you were going to do it, I'm suggesting the purge trigger just in case you have two windows open on the same layout cellView at the same time.
