  3. How to use symbols (units) in string?
  • Views 18644
HarisNoman513
HarisNoman513 over 8 years ago
Dear Cadence Community,
I have a small query.
How can we use unit symbols while printing a certain string?
e.g. 1kΩ .
How can i add this Ω symbol for Ohm in the string?
Also, how to add subscripts and superscripts to it?
e.g Ω^-1 for 1/Ω
Haris
    Andrew Beckett over 8 years ago +1
    Hi Haris, You can't. Virtuoso has primarily 7-bit ASCII support, with some limited 8-bit ASCII support. For characters with an ASCII code above decimal 127 (177 in Octal) as on this page , you can use…
    Hi Haris,
    You can't. Virtuoso has primarily 7-bit ASCII support, with some limited 8-bit ASCII support. For characters with an ASCII code above decimal 127 (177 in Octal) as on this page, you can use (for example);
    printf("Fraction \276\n")
    will output:
    Fraction ¾
    However, characters like the Greek Omega symbol is not possible - that would require Unicode support, which is not available throughout Virtuoso.
  • HarisNoman513
    HarisNoman513 over 8 years ago in reply to Andrew Beckett
    Thankyou for your detailed response.
    Much appreciated.
    Haris
