  3. disable auto-generation of thumbnails in .cdsinit through...
  • Subscribers 150
  • Views 14834
disable auto-generation of thumbnails in .cdsinit through envSetVal does not work
qkoyote
qkoyote over 8 years ago
I want to disable auto-generation of thumbnails in .cdsinit , but it does not work. I put the following setting into .cdsinit file.
envSetVal("ui.thumbnails" "enable" 'boolean t)
envSetVal("ui.thumbnails" "generate" 'boolean t)
I want to know how to set these variables in .cdsinit.
qkoyote
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
     These env vars impact the library manager thus they must reside in the appropriate .cdsenv file and should not be defined via .cdsinit.
    To disable the auto-generation of thumbnails you need to add to .cdsenv:
    ui.thumbnails generate boolean nil
    To disable displaying and generating thumbnails you need to add the following command to the .cdsenv - enable variable overrides the settings in generate variable so setting enable to nil is enough:
    ui.thumbnails enable boolean nil
    Dimitra
