  3. How to check if MPT functions are available in a running...
  • Views 16150
How to check if MPT functions are available in a running environment?
crizos
crizos over 8 years ago
Hi all,
I was wondering if there is a way to determine whether a Virtuoso version is for advanced node technology (ICADVANCE) or not, using SKILL. The purpose is to check if the multi-patterning technology (MPT) SKILL functions are available.
Chris
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
    Hi Chris,
    Try this:
    rexMatchp("ICADV" cadr(parseString(getVersion(t))))
    If it returns t that means you are using the ICADV version.
    Dimitra
  • crizos
    crizos over 8 years ago in reply to Dimitra Papazoglou
    Dear Dimitra,
    The function getVersion was considered but appears to be an unsafe solution.
    Provided that executing a MPT function in a non-advanced version prompts a warning message (e.g. WARNING (TECH-251000): techGetLayerNumColorMasks: This functionality is only available in the advanced node release. ) it seems that there is a build-in functionality which checks the running version.
    Is there a way to use that functionality directly and avoid string manipulation?
    Many thanks,
    Chris
    Andrew Beckett over 8 years ago in reply to crizos
    Chris,
    Unfortunately there doesn't seem to be a public SKILL function that determines this. You can't use isCallable on the functions because they are defined in IC617 as well, but disabled. So I think there needs to be a public equivalent of the current private function. I'll file a request for such a function.
  • crizos
    crizos over 8 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for your answer, I will re-consider the getVersion solution for the time being, which Dimitra also proposed.
    Many thanks,
    Chris
