  3. How to access from skill the psf dirs of a parametric analysis...
  • Views 16379
How to access from skill the psf dirs of a parametric analysis?
Marcel Preda
Marcel Preda over 8 years ago
Hi there,
How can I access from skill the results directories of a parametric analysis.
Saving it as ocean file the swept variables looks like this
paramAnalysis("Vsel" ?values '(1 2 3 ) ?sweepType 'paramset
paramAnalysis("Vesd" ?values '(2000 2000 4000 ) ?sweepType 'paramset
paramRun( ?jobName "job" ?drmsCmd "ifxADEL -tools=mmsim -ncpu=2" )
What I want is that people run a parametric analysis and then a script to automatically identify the psf dirs, to postprocess  spectre.out and eventually to postprocess the 'tran result database from the same dir(based on what we found in spectre.out).
Right now the code looks like this:
sId = asiGetCurrentSession()
topPsfDir = asiGetResultsPsfDir(sId)
and then we parse the runObjFile file from the respective topPsfDir, but there we have some problems.
I hope there is something better than this approach (an API).
virtuoso version v6.1.5+
assumption is that the skill script will be run immediately after the parametric analysis (it could be a "Parametric Set" or "Sweep & Ranges").
Best Regards,
Marcel
    Hi Marcel,
    I must be missing something.
    Why do you need to parse the runObjFile to find the individual member tran results - if you open the results directory with the runObjFile, it automatically gives you a family of results? It seems excessive to go through these steps just to find the individual run directories when accessing the root of the results will give you all of them.
  • Marcel Preda
    Marcel Preda over 8 years ago in reply to Andrew Beckett
    It is an old inherited code which was reading the runObjFile, so now we try to improve it.
    As I've mention I want to access each individual psf directory and then to process spectre.out and the waveforms results for the respective sweep and to create some reports which collects data from spectre.out (warning messages) and from 'tran database.
    Each report (some CSV files) is specific for a combination of swept parameters.
    Assuming that I know topPsfDir = asiGetResultsPsfDir(sId) , do we have a standard way to get each individual psf result directory?
    Best Regards,
    Marcel
    Andrew Beckett over 8 years ago in reply to Marcel Preda
    Hi Marcel,
    I think the simple answer is "no". There are some private APIs for dealing with runObjFiles, but they're not really suitable (even if they were documented) for use - they're too low level, and don't really provide the information you want.
