  3. ADE XL setup not working properly.
  • Subscribers 148
  • Views 7852
FormerMember
FormerMember over 8 years ago
Hi.
I use IC6.1.7 - I've just setup the software, via installscape, and using my institutions license server. All of that is working.
I have a simple schematic that works fine simulating in ADE L , using a DC analysis. I am not using a config view.
I launch ADE-XL , the working tests from ADE-L are imported. However I cannot plot any results, like used to work in ADE-L.
I get the following messages (in red) in the CDS.log viewer, when I first launch the ADE-XL.
*Error* Cannot copy "" from "/home/andy/cadence/installs/IC617/sims/comparator_tb/spectre/schematic/netlist" to "/home/andy/cadence/installs/IC617/sims/stochasticADC/comparator_tb/adexl/results/data/.tmpADEDir_andy/stochasticADC:comparator_tb:1/stochasticADC_comparator_tb_schematic_spectre/netlist", cpDataDir call returned 0
<<< Stack Trace >>>
(... in _axlTarCopyWrapper ...)
(... in unknown ...)
(... in _axlImportADELTestInADEXL ...)
(... in _axlImportTestInADEXL ...)
_axlImportTestInADEXL('sevSession25 ?appName "ADE XL" ?tool "ADE")
Then when trying a single simulation run in ADE-XL I get:100
*Error* Error during netlisting of design for the point ID (0 1).
("error" 1 t nil ("*Error* Cannot copy \"netlist into run netlist\" from \"/home/andy/cadence/installs/IC617/sims/stochasticADC/comparator_tb/adexl/results/data/Interactive.0/1/stochasticADC:comparator_tb:1/netlist\" to \"/home/andy/cadence/installs/IC617/sims/stochasticADC/comparator_tb/adexl/results/data/Interactive.0/psf/stochasticADC:comparator_tb:1/netlist\", cpDataDir call returned 0"))
ERROR (ADEXL-5025): Preparation to run the simulation is failed for the run Interactive.0, point 1, test stochasticADC:comparator_tb:1, received error:
Error:
Error while preparing to run the simulation.
Cannot copy "netlist into run netlist" from "/home/andy/cadence/installs/IC617/sims/stochasticADC/comparator_tb/adexl/results/data/Interactive.0/1/stochasticADC:comparator_tb:1/netlist" to "/home/andy/cadence/installs/IC617/sims/stochasticADC/comparator_tb/adexl/results/data/Interactive.0/psf/stochasticADC:comparator_tb:1/netlist", cpDataDir call returned 0
For details open log: /home/andy/CDS.log for the point: (0 1)
    This looks like the problem in article 20130330. Most likely you've put $CDSHOME/bin in your path only, and so it can't find the cpDataDir script in the installation. Currently there's a requirement that you (also) have $CDSHOME/tools/dfII/bin in your UNIX path too.
    When I didn't have tools/dfII/bin in my path, I see this error, as well as getting:
    sh: cpDataDir: command not found
    appearing in the terminal window several times.
    Can you try that?
  • FormerMember
    FormerMember over 8 years ago in reply to Andrew Beckett
    Andrew,
    Thanks yes it was the PATH setting.
    Andy
