  3. Plot expressions containing mathematical operations using...
  • Views 15404
Plot expressions containing mathematical operations using SKILL
KGh94
KGh94 over 8 years ago
I defined the expression " VNPP("/M0" "total") * 2 "  as an output in my assembler view. When extracting the output to a CSV using awvSaveToCSV( .. ), I get the error: *Error* error: basic_string:: _s_construct NULL not valid - nil. This problem happens when arithmetic operators exist in the expression.. Is there a known fix for this problem?
Any hints would be highly appreciated.
Best regards,
Karam
    Well, I just tried using the same expression and passing the results of it to awvSaveToCSV, and it works fine. You'll need to provide more context on how you're using it.
