  3. Removing Temperature from Corner in Maestro using SKILL
  • Views 15971
KGh94
KGh94 over 8 years ago
I have a corner defined with temperature value 20. I would like to disable the temperature variable (perhaps value nil) but I am not able to find a maestro/ADE-XL function for this purpose.
Update: It can be changed using maeSetVar( .. ), but setting the value to nil does not help.. I would like to disable temperature from corners so I can use it as a parameter
Any pointers would be appreciated.
Best regards,
Karam
    Andrew Beckett over 8 years ago +1
    Hi Karam, Entered commands in bold - results on lines below: sess=axlGetWindowSession() "session0" sdb=axlGetMainSetupDB(sess) 1001 axlGetCorners(sdb) (1320 ("PVT" "FF" "SS" "NN" "MC" "C2" ) ) c=axlGetCorner…
    Hi Karam,
    "session0"
    1001
    axlGetCorners(sdb)
    (1320
       "C2"
    c=axlGetCorner(sdb "FF")
    1334
    axlGetVars(c)
    (1335
       ("temperature" "vdd")
    axlGetVar(c "temperature")
    1336
    axlRemoveElement(axlGetVar(c "temperature"))
    t
    axlGetVars(c)
    (1335
       ("vdd")
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Works perfectly.. Thanks Andrew!
