  3. Cannot overwrite default layout bindkey in ICADV
  • Subscribers 150
  • Views 16289
ddsab
ddsab over 8 years ago
I am attempting to overwrite a default layout bindkey, but the desired command will not remain in the command field once entered.  Using ICADV12.3 I have tried updating my bindkeys in the following ways:
1) In my .cdsinit I load a .bindkeys file via: load(".bindkeys")
In my .bindkeys file I wish to overwrite the default bindkeys for Ctrl and Shift<Key>H with the following commands:
hiSetBindKeys( "Layout" list(
     list("Ctrl<Key>H" "getCurrentWindow()->segSnapMode = \"anyAngle\" getCurrentWindow()->snapMode = \"anyAngle\"")
     list("Shift<Key>H" "getCurrentWindow()->segSnapMode = \"orthogonal\" getCurrentWindow()->snapMode = \"orthogonal\"")
2) From the CIW I navigate to Options>Bindkeys.  In the Layout tab I navigate to the command for bindkey Ctrl<Key>H and replace the contents of the command field with:
     getCurrentWindow()->segSnapMode = "anyAngle" getCurrentWindow()->snapMode = "anyAngle"
The bindkey is successfully updated for the 'orthogonal' command and works as intended, but is unsuccessful for the 'any angle' command.  In either case, the default bindkey for Ctrl<Key>H [geDSAFreeze(hiGetCurrentWindow()  hiGetPoint(hiGetCurrentWindow()))] is kept.  There are also no warnings or errors reported in the CIW when I load(".bindkeys").
Any help would be greatly appreciated.
Cheers,
Daron
  • Quek
    Quek over 8 years ago
    Hi Daron
    Perhaps it might be better to use the following SKILL script to toggle between orthogonal/anyAngle modes:
    procedure( CCStoggleSnapModes()
       let( (win)
          win=hiGetCurrentWindow()
          if( win~>segSnapMode=="anyAngle" then
             win~>segSnapMode="orthogonal"
             win~>snapMode="orthogonal"
          else
             win~>segSnapMode="anyAngle"
             win~>snapMode="anyAngle"
          ) ;if
       ) ;let
    ) ;procedure
    hiSetBindKey("Layout "Shift<Key>H" "CCStoggleSnapModes()")
    Best regards
    Quek
  • ddsab
    ddsab over 8 years ago in reply to Quek
    Quek,
    Thanks for the reply!  I ended up just assigning the 'anyAngle' command to another bindkey, but this may be a more elegant solution.  Though, it still wont explain why I cannot assign any command to the Ctrl<Key>H bindkey.
    Cheers,
    Daron
  • Quek
    Quek over 8 years ago in reply to ddsab
    Hi Daron
    You should use small letter "h" and not big "H" in hiSetBindKeys cmd:
       list("Ctrl<Key>h" "getCurrentWindow()->segSnapMode = \"anyAngle\" getCurrentWindow()->snapMode = \"anyAngle\"")
       list("Shift<Key>h" "getCurrentWindow()->segSnapMode = \"orthogonal\" getCurrentWindow()->snapMode = \"orthogonal\"")
    Best regards
    Quek
