  3. stretchable gui function
  • Views 16527
psill000
psill000 over 8 years ago
Sorry for not taking better notes during the skill training.
What was the skill function that would allow the GUIs to be stretchable?
You would nest the hiCreate(float, string, ...) inside the functions if my bad memory serve me right.
Paul
  • skillUser
    skillUser over 8 years ago
    Hi Paul,
    Maybe you are talking about the hiCreateFormLayout() function?  Otherwise you can use the ?attachmentList argument to hiCreateAppForm() to designate if/how a field is stretchable.
    Hope this helps!
    Lawrence.
  • psill000
    psill000 over 8 years ago in reply to skillUser
    I use the hiCreateAppForm, but I dont see the option to make the fields stretchable?
    Does it matter I define the size of the fields?
    Paul
  • dmay
    dmay over 8 years ago in reply to psill000
    You need to use the ?attachmentList option for hiCreateAppForm. This argument takes a list with a value for each field in your form. Please check the documentation for examples.
    Derek
  • skillUser
    skillUser over 8 years ago in reply to psill000
    Hi Paul,
    I think that you might also have to define the initial size of the form? The maxSize and minSize are helpful in controlling the extent of the stretching - for example you can limit the form to only stretch in one dimension if you get the numbers entered correctly but it can be 'fiddly' to arrange initialSize, minSize and maxSize to work together correctly.
    Hope this helps.
    Lawrence.
  • psill000
    I was able to use the attachment List option to work as I wanted.
    Thanks the info to get me in the direction I needed
