  3. Remove automatic parameter legend entries from sweep result...
  • Views 15308
Remove automatic parameter legend entries from sweep result plot
Jan Cools
Jan Cools over 8 years ago
Dear all,
I have my own Ocean script performing a DC sweep and then plotting the results. I generate my own legend label string to be used in the plot. However in ViVA there is always an automatic part in the legend which I cannot control (and it does not always function correct (it leaves parameters out). How can I disable this automatic entry in the legend? Hereunder is an example of what I mean:
plot(gmgds_gmoverid ?expr list(legendString) is used to plot the results of the 3 sweep simulations.
Thanks in advance
    Which version are you using? How exactly are you generating the plots - I'm not sure I'd expect it to behave this way - so there must be some subtlety to your example which is not obvious...
