  3. ViVa waveform Radix control
  • Subscribers 150
  • Views 19083
DavidLou
DavidLou over 8 years ago
hello export,
we run simulation by Ocean script and picked specific signals to be plotted. what we noticed is when ViVa displays digital bus signals (e.g., by plot(getData("/cmd_ascii[31:0]") ?expr '("CMD_ASCII"))) , seems it always display Hex value until we manually pick the Radix to Decimal or Ascii, etc. is there a way for me to specify it to display in Decimal / Ascii directly instead of manual picking every time?
default display:
after manually pick the desired Radix:
thanks,
David
IC6.1.7-64b.500.9
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
    Hi David,
     In your Ocean script you can use the awvCreateBus() to specify the radix of the digital waveform as below:
    For Ascii:
    plot( awvCreateBus("CMD_ASCII" list(getData("/cmd_ascii[31:0]")) "Ascii")  ?expr list("CMD_ASCII"))
    For Signed Decimal:
    plot( awvCreateBus("CMD_SDEC" list(getData("/cmd_ascii[31:0]")) "Signed Decimal")  ?expr list("CMD_SDEC"))
    For Unsigned Decimal:
    plot( awvCreateBus("CMD_UDEC" list(getData("/cmd_ascii[31:0]")) "Unsigned Decimal")  ?expr list("CMD_UDEC"))
    Other acceptable values for radix are: "Binary", "Octal", "Hex".
    Also, there is the following command that could be added to the .cdsinit to specify the default radix. However, I see that it works in IC616 but not in IC617. I shall file CCR...
    envSetVal("viva.digitalBusTrace" "radix" 'string "sdecimal")
    Dimitra
  • DavidLou
    DavidLou over 8 years ago in reply to Dimitra Papazoglou
    Thanks Dimitra,
    I tried "plot( awvCreateBus("CMD_ASCII" list(getData("/cmd_ascii[31:0]")) "Ascii") " but it still displays as Hex value. is it really work at your side?
    thanks,
    David
    Dimitra Papazoglou over 8 years ago in reply to DavidLou
    Hi David,
    Ok, I was using a different release than you where "plot( awvCreateBus("CMD_ASCII" list(getData("/cmd_ascii[31:0]")) "Ascii") " plots in Ascii.
    I tried now with IC6.1.7-64b.500.8 - don't have IC6.1.7-64b.500.9 at my environment- and see the same results with you.
    You can try to upgrade your release if possible. I tried for example with IC6.1.7-64b.500.12 and the latest IC6.1.7-64b.500.21 and the above plots in Ascii.
    If you insist to stay with your current version I just realized that "viva.digitalBusTrace" works as expected with IC6.1.7-64b.500.8 - I guess with yours as well. Don't see that it works with latest release though.
    So you can enable the following in the .cdsinit and then "plot(getData("/cmd_ascii[31:0]"))" will plot in Ascii by default.
    envSetVal("viva.digitalBusTrace" "radix" 'string "ascii")
    Other values for radix can be : "binary" "octal"  "hex"  "sdecimal"  "udecimal"
    Dimitra
  • DavidLou
    Thanks Dimitra,
    I'll wait until newer version becoming available then. I don't want to make Ascii as default because I do have other bus to display as hex values.
    thanks,
    David
