  3. "area" parameter missing from auCdl netlist
  • Subscribers 150
  • Views 2123
srikumarDA
srikumarDA over 8 years ago
When I am trying to generate the auCdl netlist, "area" parameter name is missing from the netlist.
EXPECTED NETLIST:
.SUBCKT fet_test nd_net sx_net
*.PININFO nd_net:B sx_net:B
DD0 sx_net nd_net tdndsx area=1.0p m=1 perim=4.0u dtemp=0.0
.ENDS
COMING NETLIST:
DD0 sx_net nd_net tdndsx 1.0p m=1 perim=4.0u dtemp=0.0
.ENDS
CDF CODE:
termOrder = '(plus minus)
cdfCreateParam(cdfId
      ?name           "area"
      ?prompt         "Parasitic Area"
      ?defValue       "1.0p"
      ?type           "string"
      ?parseAsCEL     "yes"
      ?parseAsNumber  "yes"
      ?storeDefault   "yes"
    cdfId->area->minValue = "0.0"
      ?name           "perim"
      ?prompt         "Parasitic Perimeter"
      ?units          "lengthMetric"
      ?defValue       "4.0u"
      ?type           "string"
      ?parseAsCEL     "yes"
      ?storeDefault   "yes"
    cdfId->perim->minValue = "0.0"
auCdlInfo                      = '(nil)
    auCdlInfo->netlistProcedure    = '_ansCdlCompParamPrim
    auCdlInfo->instParameters      = '(area perim dtemp m)
    auCdlInfo->componentName       = modelName
    auCdlInfo->termOrder           = termOrder
    auCdlInfo->namePrefix          = "D"
    auCdlInfo->modelName           = modelName
    auCdlInfo->propMapping         = '(nil AREA area PERIM perim)
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
     The following article should solve your issue:
    How to output the area and pj keywords for a diode device in the auCdl netlist file
    Dimitra
  • srikumarDA
    srikumarDA over 8 years ago in reply to Dimitra Papazoglou
    I am not able to open the link. Can you please tell me the document name
    Dimitra Papazoglou over 8 years ago in reply to srikumarDA
    The link refers to an article not to document. You need to create an account to the Cadence Online Support site to access the link. If you are student you might need to contact with your professor or a person with fully access to Cadence Online Support or you can ask help from Europractice which typically provides support to universities.
    As the article describes, in order to print out the area in the auCdl netlist what you need to do is to change the netlistProcedure to ansCdlSubcktCallExtended in the CDF.
    Dimitra
  • srikumarDA
    Thanks for your help.
    I found it.
