  3. Auto-update QRC form based on a specific field being mo...
  • Subscribers 150
  • Views 15071
Auto-update QRC form based on a specific field being modified
frankp
frankp over 8 years ago
Hello Cadence folk,
(ICADV12.30.ISR15)
Concerning the QRC form, "Setup" Tab:
I would like for the view name of the extracted output view to be modified upon a change in the "RuleSet" field (drop-down menu).
In other words, if the ruleset is changed to "ruleset_typical" the (extracted) view name will automatically be modified to "av_extracted_typical"  and so on. Is there a way to do this ?
Frank
  • Quek
    Quek over 8 years ago
    Hi Frank
    You can do it as follows:
    a. Save the following codes in a file named "vuiUserDefinedRCXFormSetupCB.il"
    procedure( vuiUserDefinedRCXFormSetupCB(form)
      prog( (setupTab)
          when( form~>hiFormSym=='vuiRcxRunForm
             setupTab=_vuiRcxGetTabField("vuiRcxRunForm" "setupTab")
             when( setupTab~>outputFormat~>value=="Extracted View"
                setupTab~>ruleSetField~>_callback="_vuiRcxSetupDirCB_q()"
             ) ;when
          ) ;when
          return(t)
       ) ;prog
    ) ;procedure
    procedure( _vuiRcxSetupDirCB_q()
       let( (setupTab ruleSet)
          _vuiRcxSetupDirCB()
          ruleSet=setupTab~>ruleSetField~>value||""
          setupTab~>extractedView~>value=strcat("av_extracted_" ruleSet)
       ) ;let
    ) ;procedure
    b. Load it in CIW using:
    load "./vuiUserDefinedRCXFormSetupCB.il"
    c. Open Quantus form and try changing the ruleset
    Best regards
    Quek
  • frankp
    frankp over 8 years ago in reply to Quek
    Thanks Quek,
    Looking at the code, it seems to be doing exactly what I was searching for - haven't given it spin yet though.
    Frank
