  3. filter out warn msg ( SCH -2162) symbol "***" has been updated...
  • Views 2470
filter out warn msg ( SCH -2162) symbol "***" has been updated since "***" schematic was last saved.
mlea
mlea over 8 years ago
im trying to  avoid from output to CIW  these kind of warnings. Im running a skill script that recursivly filter down the hirarchy,
and each time the schematic data is newer than the symbol data  - i get these warn msg. and lot of them.
i tried the  few different approaches ( getWarn ) - none of them  was effective. i also did some reading and I do understand that the time stamp that used to be on previous IC version isn't being used today.
what is the correct method to completely get rid of this specific warn ? .
Thx
meny
    Hi Meny,
    So how are you traversing the hierarchy? I'd only expect these messages to happen if you're opening them with the schematic editor - rather than using db functions. Are you opening the designs in readonly mode? If so, using:
    envSetVal("schematic" "readOnlyCheckEnabled" 'boolean nil)
    might stop it doing the check (I didn't test this - it's a holiday in the UK today so this is a very quick answer). If I knew more about what you're doing I could probably give a more directed answer.
    Worst case it ought to be possible to redirect the warnings - but I wanted to understand more about the approach you're taking before suggesting that.
  • mlea
    mlea over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    im using the db function: dbOpenCellViewByType()  to traverse through the hierarchy.
    but only NOW I see that the first recursive loop, which start from  the top of the design, using  cv= geGetEditCellView(). would that be a problem ?
     Im open the different hierarchies for read only mode.
    thx
    Meny
    Andrew Beckett over 8 years ago in reply to mlea
    Hi Meny,
    That's strange. Are you using any sch functions in your code? I can't see why it would complain otherwise...
    Using geGetEditCellView at the top level shouldn't cause this.
