  3. Check Area and Density for specific cell
  • Views 17066
Mahesh gunde 1
Mahesh gunde 1 over 8 years ago
Hi all,
I am finding a Area and Density in my Active window using this command.
leComputeAreaDensity(hiGetCurrentWindow() list(list(list("M1" "drawing"))) ?depth 31 ).
but here I need to give window ID as given hiGetCurrentWindow().
Is it possible to do same thing for specific cells: eg "libname" "cellname".
I have a celllist here like this :
libname       cellname
"test"           "DM1"
"test"           "DM2"
anyone having Idea on this ?
Mahesh
    Andrew Beckett over 8 years ago +1
    Hi Mahesh, There's no function to do this which accepts a cellView id (or a lib/cell/view name). So the only way to do this is to (say) call geOpen for each lib/cell/view combination and pass the return…
    Hi Mahesh,
    There's no function to do this which accepts a cellView id (or a lib/cell/view name). So the only way to do this is to (say) call geOpen for each lib/cell/view combination and pass the return value of that function (which is a window id) to leComputeAreaDensity. It seems a reasonable enhancement request that we have a non-UI based function to do this, so I suggest you contact customer support so that an enhancement request can be filed with R&D. Actually, I just checked - there's an existing CCR, 1424262, asking for this - would be worth you contacting support so that a duplicate can be filed (this increases the likelihood of it being done sooner).
  • Mahesh gunde 1
    Mahesh gunde 1 over 8 years ago in reply to Andrew Beckett
    Thanks for your quick response.
    Mahesh
