  3. Writing Test result data on a .txt file
  • Subscribers 150
  • Views 16988
Boyan
Boyan over 8 years ago
Hello all ,
Im trying to save test results for a simulation into a txt file.
I have the following code:
definitionFile(
    "$PRJ_HOME/global_src/model/models.scs"
analysis('ac ?start "1"  ?stop "100M"  ?dec "20"  )
desVar(      "Vsweep" 1    )
envOption(
    'analysisOrder  list("stb" "dc" "ac")
temp( 27 )
run()
selectResult( 'ac )
plot(getData("/Output") getData("/net5") )
var = VF("/net04")
hardCopyOptions(?hcOutputFile "testFile.png" ?hcTmpDir "/home/bshabans" )
hardCopy()
data = ocnPrint(var)
/*sprintf(data "%t" data)*/
summaryFile = outfile("testFile.txt")
printf(summaryFile "data %s %n " temp() ocnPrint(var))
close(summaryFile)
The problems is that printf wont acept what is in data and doesnt want to write it on the txt
Error I am getting : Error* printf: argument #1 should be a string (type template = "tg") at line 32 of file
  • mschw
    mschw over 8 years ago
    you have to use fprintf  instead of printf.
    Kind regards,
    Matthias
  • skillUser
    skillUser over 8 years ago
    Hi Boyan,
    Also it is worth noting that ocnPrint can accept a port object for the ?output argument, so it can print directly to the file.
    Best regards,
    Lawrence.
