  3. pac analysis, how to find available sidebands?
  • Views 15836
MikeVP
MikeVP over 8 years ago
I'd like to have some skill code that tells me the available sidebands from a pac analysis.  Manually, you can see them ADE-L->Results->Direct Plot->Main Form->pac, Sweep=sideband, Output Sideband pane.
I've tried:
session=asiGetCurrentSession()
analysis = asiGetAnalysis( session 'pac)
analysis->?
(name parent scopeStore scope valid
modified data type prompt formatFunc
enable continuable oceanOnly form formInitCB
formApplyCB formType advAnaObject
Is it available in one of these?
    With the results open (either after simulation, or using openResults()) simply use one of:
    harmonicFreqList(?result 'pac)
    ((-3 9.9e+09 9.999e+09)
    (-2 4.9e+09 4.999e+09)
    (-1 1000000.0 1e+08)
    (0 5.001e+09 5.1e+09)
    (1 1.0001e+10 1.01e+10)
    (2 1.5001e+10 1.51e+10)
    (3 2.0001e+10 2.01e+10)
    harmonicList(?result 'pac)
    (-3 -2 -1 0 1
    2 3
  • MikeVP
    MikeVP over 8 years ago in reply to Andrew Beckett
    Thanks!  That is perfect!
    In the future, is there a place where I can look up functions that are specific to a particular analysis?
    Andrew Beckett over 8 years ago in reply to MikeVP
    All I did in this case (to remind me what to do) was type ocnHelp() in the CIW - then ocnHelp('harmonicFreqList) to see the details.
