  3. Extract critical path in the layout using SKILL
  • Views 15538
farhan89
farhan89 over 8 years ago
 is is there any command to extract the critical path or the longest path from input to output ? This longest path length is based in the number of devices in between the input and the output port
For example: IN-M1-M2-M3-M4-OUT and IN-M3-M4-OUT,  The critical path is IN-M1 -M2-M3-M4-OUT because there are 4 transistors between IN and OUT pin.
    Andrew Beckett over 8 years ago +1
    Not as far as I know - this is presumably just your definition of what counts as a critical path or longest path - I think you'd need to write some traversal code to extract such information based on your…
    Not as far as I know - this is  presumably just your definition of what counts as a critical path or longest path - I think you'd need to write some traversal code to extract such information based on your definition.
