  3. question about Ocean "resultsDir"
  • Views 1980
DavidLou
DavidLou over 8 years ago
hello export,
I'm trying to run an ocean script multiple times simultaneously as regression. for that, I need each simulation to go different directory without clashing other running ones. but seems ”resultsDir“ command only relocates psf result, not the netlist folder which still located at "~/simulation/top_test/ams/cosim_config/netlist/".
should there be any other command I can use to redirect the netlist folder?
thanks a lot,
David
IC6.1.7-64b.500.9
simulator( 'ams )
solver( 'Spectre )
; for config based case
design( "lib" "top" "cosim_config" "r")
resultsDir( result_dir )
ocnAmsSetOSSNetlister()
connectRules("ConnRules_mid")
modelFile(
'("....._usage.scs" "tt_lib")
analysis('tran ?stop "1" ?errpreset "conservative" )
envOption(
'amsIEsList '((t "global" "" "1.8" "connectLib.CR_full_fast" "" "logic" "discipline=logic;" "Built-in"))
'builtinuser nil
temp( 27 )
run()
    You would need to change the projectDir env var to change the top level dir for each run before you call the simulator() function (envSetVal("asimenv.startup" "projectDir" 'string "...")
  • DavidLou
    DavidLou over 8 years ago in reply to Andrew Beckett
    perfectly working now. thanks Andrew.
