  3. skill script to add layout pin for given metal intersec...
  • Replies 10
  • Subscribers 150
  • Views 22178
skill script to add layout pin for given metal intersect
GDCRA
GDCRA over 8 years ago
Lets say I have metal 9 and metal 10 intersecting each other. I want to add layout pin at all the location where these 2 metal intersect. Pin name should be same as metal 9 label.
Is there simple script that can do the job ?
GC
  • psill000
    psill000 over 8 years ago in reply to GDCRA +1
    Here's something to get you started. Disclaimer dont know env and I did some simple tests of the functionality of the script. Edit the script to your application. How to: set the layers you want…
  • psill000
    There's a lot question of the environment and results:
    Are the metals at cellview or in hierarchy?
    Is there connectivity on the wires, labels or something else?
    Is there more than one intersection?
    Maybe the quickest way to solve the problem would be to use leHiMarkNet.
    Then save the markNet of the two nets and do a Boolean on the intersections.
    Paul
  • GDCRA
    GDCRA over 8 years ago in reply to psill000
    Hi Paul,
    Metal are at cellview.  There is connectivity on wires.
    There are more than one intersection.
     leHiMarkNet may not work since I expect atleast 5-6 thousand intersection point. Its massive layout.
    GC
    Andrew Beckett over 8 years ago in reply to GDCRA
    I'd probably use dbLayerAnd or maybe abeLayerAnd if you need the capacity - this would find the overlapping regions of metal9 and metal10 and end up with a set of candidate pin shapes (presumably on metal9 - you didn't say). You could then iterate over the list of shapes and for each use dbShapeQuery to find the shape on metal9 underneath the rectangles you've created. Then use dbCreatePin using the ~>net of that shape and the rectangle you've found from the dbLayerAnd operation as the pin figure.
    Seems a bit of an odd requirement though - presumably you'd end up with a lot of pins which might not be terribly accessible - but maybe I can't visualise what your layout looks like. It's unlikely to be anything that is a standard feature because it sounds rather specific to how your  layout is constructed.
  • psill000
    More questions or possible ways to get a solution.
    Are you looking for help on writing or something already written?
    Is there more than two layers involved?
    You could do a search for the two layers with the nets you want copyFig to a tmp layer and do a Boolean on the intersections to output your pin locations
    dbCreatePin from the Boolean nad delete the tmp shapes.
    Paul
  • GDCRA
    GDCRA over 8 years ago in reply to Andrew Beckett
    Hi Andrew, I could scramble only upto following code. I am having difficulty to iterate over list of shapes. If its fairy quick, do you mind giving me actual code ?.
    Here is what I could write
    M8 = abeLayerFromCellView( "M8" ?purpose "drawing" )
    M9 = abeLayerFromCellView( "M9" ?purpose "drawing" )
    OverlapLayer= abeNewLayer()
    abeLayerAnd( M8 M9 OverlapLayer )
    I am struggling with dbShapeQuery and beyond logic.
    GC
  • psill000
    How to:
    set the layers you want to pin be visible
    load the file and and drop the command in the CIW
    command example: genPin("baam" "booyaa" '("M3" "pin") "M3M4" '("M3" "label") )
    ------------------------------skill script-----------------------------------------------------
    procedure(genPin(net1 net2 pinLpp pinNet labLpp)
    when(getMode()
             genPinExe(net1 net2 pinLpp pinNet labLpp))
    procedure(getMode()
    let(((bool t))
    if(equal(geGetEditCellView()~>mode "r") then
             printf("Cell is in read only mode.\n")
             bool = nil)
    bool
    procedure(genPinExe(net1 net2 pinLpp pinNet labLpp)
    let( (netDb tmp delTmpList labDb
             (tmpLp0 '("y0" "drawing"))
             (tmpLp1 '("y1" "drawing"))
             (cv geGetEditCellView()))
    netDb = dbFindNetByName(cv pinNet)
    unless(netDb netDb = dbCreateNet(cv pinNet))
    foreach(shp setof(s cv~>shapes leIsLayerVisible(s~>lpp))
             cond( (equal(shp~>net~>name net1)
                               tmp = dbCopyFig(shp cv)
                               tmp~>lpp = tmpLp0
                               delTmpList = cons(tmp delTmpList))
                      (equal(shp~>net~>name net2)
                               tmp~>lpp = tmpLp1
    foreach(pin leLayerAnd(cv tmpLp0 tmpLp1 pinLpp)
             dbCreatePin(netDb pin)
             labDb = dbCreateLabel(cv labLpp centerBox(pin~>bBox) pinNet "centerCenter" "R0" "stick" 0.015)
             leAttachFig(labDb pin))
    foreach(tmp delTmpList dbDeleteObject(tmp))
    t
    ); end of let
    ); end of genPinExe
    Something like this. My technology had layers called Metal8 and Metal9 (and I put the pins on Metal7 for visibility, with the connectivity info coming from the Metal8 shapes).
    Using dbLayerAnd would have been slightly easier, because then you'd get a list of the pin shapes directly which you could iterate over using foreach - but it's a good example of the abe functions nevertheless:
    cv=geGetEditCellView()
    abeInit(cv)
    M8LayerName="Metal8"
    M9LayerName="Metal9"
    pinLayerName="Metal7"
    M8 = abeLayerFromCellView(M8LayerName ?purpose "drawing" )
    M9 = abeLayerFromCellView(M9LayerName ?purpose "drawing" )
    ;; could use abeLayerToCellView to generate real shapes
    ;; but since we don't know what was produced unless
    ;; we write to an empty layer, perhaps should just iterate
    iter=abeIslandIterator(OverlapLayer)
    while(polygon=iter->next
        pinFig=dbCreatePolygon(cv pinLayerName polygon)
        underneath=dbShapeQuery(cv M8LayerName pinFig~>bBox 0 0)
        ; find the net info from any M8 shapes under the pin which
        ; have a net attribute
        net=car(exists(shape underneath shape~>net))~>net
        ; if found, convert the pin figure to a pin
        when(net
    	dbCreatePin(net pinFig)
  • GDCRA
    Thank you Paul and Andrew. Both code are working like charm if my metal are in top most cell of hierarchy. What if some of metals are down in hierarchy ? Can we modify script to travel through hierarchy ?
  • psill000
    Its a little more work to go through the hierarchy to trace a net. If you dont have a trace script you might want to try the markNet functions and save the trace to a alternate view. Then you can do the Boolean from the scripts above. After the Boolean move the shapes to your cellview and create the pins.
    If you have a cadence account you can go Cadences script library and search from there sources.
    I think this is the link to Cadences script library. Its a good resource of skill examples to get you started.
    https://support.cadence.com/
    Paul
    Andrew Beckett over 7 years ago in reply to GDCRA
    The abe functions will by default find all shapes throughout the hierarchy - there are several ways to limit this (including the ?depth argument to abeInit). If the shape with the connectivity information isn't at the top level, then you might need to increase the last argument to dbShapeQuery to increase the depth that it's looking (in my code it is 0, so only looking at the top level shapes).
