  3. Probe net across schematic hierarchy through vsource
  • Replies 7
  • Views 20942
Shankar P16
Shankar P16 over 8 years ago
Hi
I generally have lot of current probes in schematics using 0V Voltage sources. I add a net probe with geAddNetProbe() and I would like to continue the probe(on the otherside of the 0V sources) passing through the voltage sources.
I have written a following script which does the job partially. The following script looks for the currently probed net, runs across all the instances connected to the net. If there is a 0V vsource, I add another probe(with same color) on the other side of the 0V vsource.
wId = hiGetCurrentWindow()
pList = car(geGetAllProbe(wId))
pC = pList~>probeColor
pNvdc = setof(x pList~>objectId~>instTerms~>inst x~>cellName == "vsource")
foreach(p0vdc pNvdc
figs=p0vdc~>conns~>net~>figs
xy1=car(nth(0 nth(0 figs))~>points)
xy2=car(nth(0 nth(1 figs))~>points)
geAddNetProbe(wId pC xy1)
geAddNetProbe(wId pC xy2)
This works great at a particular schematic hierarchy. But doesn't work across hierarchies. For e.g. consider few lines of a netlist
I0 ( net1 netA) vsource type=dc dc=0
I1 ( net2 netB) vsource type=dc dc=0
I2 ( net3 netC) vsource type=dc dc=0
IX ( netA netB netC) myInst
subckt myInst (netA netB netC)
IY ( netA netA1) vsource type=dc dc=0
IZ ( netB netB1) vsource type=dc dc=0
ends myInst
If net1 is probed first and the aforementioned skill code is run, netA alone gets probed. But I would like to continue the probe on netA1 inside the hierarchy IX. How do I modify the code to achieve this. If there is totally a different line of thinking to achieve the same effect, that would also help!
Shankar
    Hi Shankar,
    Actually, the simplest thing to do is to ask the probe to traverse "feedthrough" cells and register the vsource as a feedthrough.
    envSetVal("graphic" "probeTraverseFeedThrough" 'boolean t)
    ciRegisterDevice("probeShort" '( (nil "vsource" nil (nil shortedTerminalMap ( ("PLUS" "MINUS") ) )) ))
    envSetVal("graphic" "probeTraverseHierarchy" 'boolean t)
    envSetVal("graphic" "probeNetDisplayHierarchyLevel" 'int 20)
    Then you can probe one of the nets and it will probe through the vsource components. Note that the code above will only have an effect on schematic windows opened after you define the env vars. You can do it for an open window with:
    hiGetCurrentWindow()->probeTraverseFeedThrough=t
    hiGetCurrentWindow()->probeTraverseHierarchy=t
    hiGetCurrentWindow()->probeNetDisplayHierarchyLevel=20
    This way you don't need to write code to follow through the vsource yourself.
  • Shankar P16
    Shankar P16 over 8 years ago in reply to Andrew Beckett
    Hi Andrew
    I tried this solution and this works great. I didn't know about this cool feature!
    The minor issue is that if there are existing probes, on a current window, I have to probe them again(remove first!) to see the final effect. However, I easily achieved that by finding all the existing probes, removing them and adding them again.
    Shankar
  • Juan Pons
    Juan Pons over 7 years ago in reply to Andrew Beckett
    Hi Andrew, I think that this "feedthrough" feature is just great! But I have a question.
    Is there a way of obtain what nets are probed after you use this technique? I have tried the geGetAllProbe(win_id) but only reports me the net I probed with the pointer. The others nets are just visually probed, they do not even appear probed in the cadence navigator.
    Regards, Juan.
    Andrew Beckett over 7 years ago in reply to Juan Pons
    Hi Juan,
    I don't think so. You might be able to see them in the Probe Assistant (I didn't have time to check - I'm catching up after vacation) (Window->Assistants->Probes) and then you can export them from there (assuming this works).
  • Juan Pons
    Hi Andrew, thanks for the response!
    Well, you are right about the probe assistant (I didn't know about it), it gives the correct information about the nets probed. I noticed that the navigator updates the information after opening the probe assistant. However, geGetAllProbe() function still gives me just those nets I probe with the pointer using geEnterAddNetProbe() function :/
    Do you know about other function to consult the correct info? Or maybe there is a way of refreshing the data that geGetAllProbe() shows.
    Regards, Juan.
    Hi Juan,
    There isn't a way of getting geGetAllProbe() to show all the other nets that are probed (it's not a matter of refresh - there is in fact only a single probe, but the probing system itself takes care of identifying all the actual nets to be highlighted; geGetAppProbe returns the list of probes, not the list of nets).
    One approach could be to use the schTraceNet function that was added in IC618/ICADVM181. This uses the probe infrastructure and so also supports the feedthrough definition in the same way. You can then use this to collect info on all the nets that are actually traced throughout the hierarchy. It's documented, and my colleague in R&D has just mentioned to me that a video is in preparation that will appear on support.cadence.com soon covering this new function. So maybe that would help you?
  • Juan Pons
    that function seems to be what I just need but unfortunately here we have the IC617 version. I think I'll just program something to recognize the groups of nets interconnected by, in my case, a metal connector. Thanks anyway!
    Regards, Juan.
