  3. using letseq or parameterized property/parameter in graphical...
  • Views 1856
using letseq or parameterized property/parameter in graphical PCell
leichtfm
leichtfm over 8 years ago
I'm trying to edit an existing graphical PCell (layout) using IC6.1.6.
There are multiple stretches & parameterized properties that share a major part of their expression.
for example:
Stretch 1:
((evalstring(w)+2.0+dx)*(nx-1))
Inherited Parameter 1:
(xTotal-((evalstring(w)+2.0+dx)*(nx-1))+0.02)
I thought about using parameterized property for the shared part, however they would not accessible within the layout.
Another idea was to use letseq with the intention to make it easier to make changes, however this would still require to change all expressions.
Besides that, there seems to be a small bug, as the parameter "width" is automatically added to the pcell parameters, even if this parameter is not used.
Stretch 1:
letseq(((w evalstring(w))(width (w+2.0+dx)*(nx-1)))) width)
letseq(((w evalstring(w))(width (w+2.0+dx)*(nx-1)))) (xTotal - width + 0.02))
Is there any flexible way to implement that?
thx in advance & best regards,
Michael
    Hi Michael,
    Not really. The Graphical PCell capability has not really been enhanced for many years, and certainly doesn't support letseq or using localised variables this way.
    If you want a graphical UI-based means of creating PCells then Cadence PCell Designer is the best way of achieving that (the link is to the data sheet - you'd need to contact your account team for more details). Alternatively, writing your PCell using SKILL could also achieve your desire of sharing computation using local variables.
  • leichtfm
    leichtfm over 8 years ago in reply to Andrew Beckett
    thank you for the fast response, I really appreciate your help.
    I'll take a look into the PCell-Designer!
    Michael
