  3. skill code to place all symbol cells in a virtuoso lib to...
  • Replies 11
  • Subscribers 150
  • Views 25698
skill code to place all symbol cells in a virtuoso lib to top level schematic cell
Nhumai
Nhumai over 8 years ago
Hi All,
I was trying to create a top level schematic which has all the symbol of cells in a schematic. What I have is
##########create a test schematic with inv symbol in it ###############
cv=dbOpenCellViewByType("sc33tps_v1" "test" "schematic" nil "a")
 cv1=dbOpenCellViewByType("sc33tps_v1" "inv"  "symbol")
  schinst=dbCreateInst(cv cv1 nil list(0 0) "R0" 1)
this code is working fine
now I want to place all the cell in "sc33tps_v1" lib in test schematic and I have
lib=ddGetObj("sc33tps_v1")
foreach (cell lib~>cells
  when(ddGetObj(lib~>name cell~>name "symbol")
      cv1=dbOpenCellViewByType(lib~>name cell~>name "symbol")
this code is not working . Please help to let me know what is wrong ?
thanks
Nhumai
    Andrew Beckett over 6 years ago in reply to annesha
    annesha said:
    Thanks Andrew! I could do the same using following code
    Only if you've compiled the pattern beforehand with pcreCompile and you don't mind all the instances being on top of each other (the code you posted will have every instance at 0:0)
