  3. skill code to place all symbol cells in a virtuoso lib to...
  • Replies 11
  • Subscribers 150
  • Views 25697
skill code to place all symbol cells in a virtuoso lib to top level schematic cell
Nhumai
Nhumai over 8 years ago
Hi All,
I was trying to create a top level schematic which has all the symbol of cells in a schematic. What I have is
##########create a test schematic with inv symbol in it ###############
cv=dbOpenCellViewByType("sc33tps_v1" "test" "schematic" nil "a")
 cv1=dbOpenCellViewByType("sc33tps_v1" "inv"  "symbol")
  schinst=dbCreateInst(cv cv1 nil list(0 0) "R0" 1)
this code is working fine
now I want to place all the cell in "sc33tps_v1" lib in test schematic and I have
lib=ddGetObj("sc33tps_v1")
foreach (cell lib~>cells
  when(ddGetObj(lib~>name cell~>name "symbol")
      cv1=dbOpenCellViewByType(lib~>name cell~>name "symbol")
this code is not working . Please help to let me know what is wrong ?
thanks
Nhumai
    You didn't give any indication of what went wrong or what errors were given. Three things that I can spot:
    1. The nil on the first line would probably be better being "schematic" so that it knows what viewType to create the view as if there is no existing "schematic" view.
    2. You've got an erroneous space after the foreach and before the parenthesis that follows it. If you use the C-style for SKILL, you must not put spaces between the function name and the parenthesis after it.
    3. All your instances will be on top of each other because you've set the xy location to list(0 0)
    With the code as (my library name):
    cv=dbOpenCellViewByType("opamp090" "testforum" "schematic" "schematic" "a")
    lib=ddGetObj("opamp090")
    foreach(cell lib~>cells
        when(cv1
    The code worked (albeit with the instances on top of each other). You could compute the coordinate yourself (if you have some idea of the size of the symbols - although you could find that out using the bBox of the symbols too). My code has an additional when to make sure it doesn't fail if the symbol couldn't be opened for some reason.
  • Nhumai
    Nhumai over 8 years ago in reply to Andrew Beckett
    Hi Andrew
    thanks for your code. I was trying to submit the code as the org thread but I can't find org thread.
    I will try to modify it so I can array them instead of put them on the top of each other
    I will keep you posted
    thanks
    Nhumai
  • Nhumai
    Nhumai over 8 years ago in reply to Nhumai
    Hi Andrew
    I got it now below is my code
    cv=dbOpenCellViewByType("sc33tps_v1" "all_cells" "schematic" "schematic" "a")
    x = 0.0
    y = 0.0
        when(cv1
          schinst=dbCreateInst(cv cv1 nil list(x y) "R0" 1)
          if( (x == 27.0) then x = 0.0 y = y + 3.0 else x = x + 3.0 )
    Thanks for your help
    Nhumai
  • Nhumai
    Now I would like to enhance the script to put the cells in alphabetical order do you have any suggestion for me ? your suggestion is very appreciated it
    thanks
    Nhumai
  • skillUser
    skillUser over 8 years ago in reply to Nhumai
    x = 0.0
    y = 0.0
    foreach(cell sort(lib~>cells lambda((x y) alphalessp(x~>name y~>name)))
        when(cv1
    Should do the trick I think.
  • Nhumai
    Nhumai over 8 years ago in reply to skillUser
    it works :-)
    but it put the cells in reverted order but that is good enough for me
    thanks all for help
    Nhumai
  • skillUser
    Hi Nhumai,
    sorry about that, you can switch the order of the x and y in the call to alphalessp -> alphalessp(y~>name x~>name)
    Best regards,
    Lawrence.
  • annesha
    annesha over 6 years ago in reply to Andrew Beckett
    Hi Andrew
    If i need to use only a particular type of cells (say 'inv') what do i add for it?
    Andrew Beckett over 6 years ago in reply to annesha
    Assuming you're asking me to update Lawrence's code in this part of the thread and by "type of cells" you mean those that begin with a certain string, then you could replace:
    with
      when(ddGetObj(lib~>name cell~>name "symbol") && pcreMatchp("^inv" cell~>name)
    The first argument to pcreMatchp would be the regular expression you want - in this case this means anything beginning with inv.
    Not really sure why you asked me... I corrected the original code but then pointed out what was wrong with it, and then Lawrence fixed it properly.
  • annesha
    Thanks Andrew! I could do the same using following code
       when(pcreExecute(pattern cell~>name)
          when(cv1
