  3. need a gui based remaster script for cells
  • Views 15046
SatendraMaurya
SatendraMaurya over 8 years ago
I wanted to replace the cells in the schematic from one lib to other and potentially different cellname
I wrote the following SKILL code:
;; liblist=ddGetLibList()~>name
;; cellist=ddGetObj("smaurya_l")
procedure( replace()
let((oldcellnameL oldcellnameS)
libNameOld=hiCreateListBoxField(
?name 'libNameOld
?numRows 6
?choices liblist
?prompt "Old Library Name"
?callback "oldcellnameL=(libNameOld~>value) println(oldcellnameL) sprintf(oldcellnameS \"%L\" oldcellnameL) println(oldcellnameS)"
cellNameOld=hiCreateListBoxField(
?name 'cellNameOld
?numRows 6
?choices ddGetObj(oldcellnameS)~>cells~>name
?prompt "Old Cell Name"
?callback "ddsUpdateSyncWithForm()"
;;new
libNameNew=hiCreateListBoxField(
?name 'libNameNew
?numRows 6
?choices liblist
?prompt "new Library Name"
newcellname=ddGetObj('libNameNew)~>name
cellNameNew=hiCreateListBoxField(
?name 'cellNameNew
?numRows 6
?choices newcellname
?prompt "new Cell Name"
randFrameField = hiCreateFrameField(?name 'myrandFrameField)
netlisterForm = hiCreateAppForm(
?name 'netlisterForm
?formTitle "Replace"
?fields list(
list(randFrameField 5:0 405:100)
list(libNameOld 10:10 400:100 100)
list(cellNameOld 10:100 400:100 100)
list(libNameNew 10:190 400:100 100)
list(cellNameNew 10:280 400:100 100)
);fields
?buttonLayout 'Close
?initialSize t
) ;hiCreateAppForm
hiDisplayForm(netlisterForm)
);let
);procedure
;;procedure( celllist(libname)
I wanted the user choose the library and then select the cells from that list.I am able to get the library list but somehow I am not able to populate the celllist of that library. I am using callback to pass on selected libname to the celllist but its always empty.
Is there a way to set variable in callback section and use it later.
Satendra'
    Hi Satendra,
    In the ?callback for libNameOld put:
    ?callback "netlisterForm->cellNameOld->choices=ddGetObj(car(netlisterForm->libNameOld->value))~>cells~>name"
    You'll need a similar callback for the libNameNew field too.
  • SatendraMaurya
    SatendraMaurya over 8 years ago in reply to Andrew Beckett
    Thanks a lot Andrew. It worked.
