  3. Displaying special characters in the Units column in the...
  • Views 2266
Displaying special characters in the Units column in the Assembler 'Outputs Setup'
pbanens
pbanens over 7 years ago
In my assembler testbench I am trying to display units that are not regular ascii characters.
In one particular case it would be nice to display 'pA per root Hertz' as pA/???Hz,  where ??? is the square root symbol
In the 'Outputs Setup' tab I would put the 'p' in the Suffix column and the rest in the Units column.
Although printf("A/\342\210\232") will correctly display in the CIW, entering A/\342\210\232 directly  in  the Units column or by loading it by a CSV file does not work.
It is displayed literally.
As I am reading these units from some specifications it would be awkward to have to deal with the non-ascii code  (I already have modified the unicode to be in octal byte format).
It there a way to get these octal bytes interpreted?
Paul
    Hi Paul,
    Good to hear from you!
    Unfortunately Unicode (specifically UTF-8 which is what you're using in this case) is not supported throughout the UI, so this is not possible.
  • pbanens
    pbanens over 7 years ago in reply to Andrew Beckett
    Oh well Disappointed
    Thanks Andrew
    After I posted the ticked I tried axlOutputPutUnits and the three octal bytes were interpreted individually.
    I guess I'll make a lookup table to replace any (common) unicode characters with text.
    Paul
