  3. Skill code to list "all the transistor hierarchical path...
  • Views 2309
Skill code to list "all the transistor hierarchical path along with their size (e.g fin number, number of finger, length) on given net"
GDCRA
GDCRA over 7 years ago
I came across this script
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVylEAE&pageName=ArticleContent&sq=005d0000005nZuVAAU_201892623257471
But it only list device. Not actual transistor and their size info.
Is their easy way to modify above code to print  transistor hierarchical path along with their size (e.g fin number, number of finger, length) on given net.
GC
    I only had a quick look at the code, but since it returns a list of the instances, couldn't you use a foreach() over the results and then print the ~>l, ~>fin etc (or whatever the parameters are called in your PDK)?
