  3. Simple question about repeated list elements.
  • Views 16015
CADcasualty
CADcasualty over 7 years ago
In my simulation scripts I'm doing a lot of waveform plotting using the awvPlotWaveform() function. Say I'm simulating over PVTs and want to plot a lot of waveforms in a separate color per PVT.  I have the color stored in a variable (color_var) so the relevant part of the plot command contains the text:
?color list( color_var color_var color_var color_var color_var color_var color_var color_var color_var color_var color_var color_var ) \
and I have the same thing for the plot_strip etc..
I searched and I searched but I couldn't find any way to define a list of repeated elements easily e.g. something like
list( 20*color_var)
I know the above syntax can't possibly work, but is there anything that does what I want?
(Note: I originally posted this about the strip_number in the awvPlotWaveform function but the forum's automated spam detector rejected my post as offensive because it contained the word strip too many times :-/)
    In this case it thought that it was spam because of the repeated text (color_var). So it probably wasn't "strip" that it had an issue with, but the repetition. Since spam often contains repeated text, unfortunately it sometimes gets confused by genuine posts such as the above. Luckily I'm the moderator and I get alerted and so can then approve the post.
    You can use this code:
    procedure(CCFrepeatedList(ntimes element)
      let((result)
        for(i 1 ntimes result=cons(element result))
        result
    Then you can just do:
    CCFrepeatedList(20 color_var)
    to generate the repeated list.
  • CADcasualty
    CADcasualty over 7 years ago in reply to Andrew Beckett
    Sorry for the late reply Andrew - I meant to say thanks for your code. I was able to make it work just fine, although I found myself needing to use the nconc() function in several places where I needed the code.  I originally thought I could use your procedure within a list declaration but, because it actually yields a list itself, I needed to concatenate all the various lists using nconc().
