  3. change waveform line thickness with bindkey in ViVa
  • Views 16710
tbaldett
tbaldett over 7 years ago
I am using IC 617.717 and I would like to know if exists a method to change waveform line thickness using/defining a new bindkey in ViVa.
e.g. I select a waveform, press bindkey "1" to set thickness to this waveform to "Fine",  and assign other thickness values to different keys ("2" Medium, "3" "Thick" "4" "ExtraThick")
I am aware I can do RMB->Width->"..." on a waveform but I would like to define a bindkey.
Please note that I am not referring to waveform viewer defaults set with envSetVal("viva.trace" "lineThickness" 'string "fine")
Best regards,
Tommaso
    Hi Tommaso,
    This is not possible currently.
