  3. How to get the cellviews hierachy
  • Replies 11
  • Subscribers 150
  • Views 25367
wenckey
wenckey over 7 years ago
In Virtuoso, if I have the target cell name "target", top cell name "top", lib name "mylib", view name "layout". How can I get the hierachy path for the "target" from "top"?
Like hierachy path: top->cellA->cellB->target
  • Marben
    Marben over 7 years ago +1
    Hi wenckey, Code below will get all the instance hierarchy path from top level. Hope it helps. ;procedure(CCFgetInstanceNamesAndCoords(master @optional (transform list(0:0 "R0" 1)) (hierInstPath…
  • skillUser
    skillUser over 7 years ago
    I think either geGetInstHierPath() or geGetInstHier() might give you what you want?
    Best regards,
    Lawrence.
  • wenckey
    wenckey over 7 years ago in reply to skillUser
    geGetInstHierPath() and geGetInstHier() need to open a cell view and descend into or EIP in a cellview. It will not report the hier path if another cell contain the target cell.
    Also thanks for your response Slight smile
  • Marben
    Hi wenckey,
    Hope it helps.
    ;procedure(CCFgetInstanceNamesAndCoords(master @optional (transform list(0:0 "R0" 1)) (hierInstPath "/"))
    procedure(ci()
    cvId=geGetWindowCellView()
    csh("touch ./instance_coord.txt")
    outPort = outfile("./instance_coord.txt")
    fprintf(outPort "\n Coordinates of instances of %s with a library %s :\n\n" cvId~>cellName cvId~>libName)
    ctr = 0
    foreach(inst master~>instances
    when(inst~>objType=="inst"
    ctr = ctr +1
    printf("%s%s %L\n" hierInstPath inst~>cellName dbTransformPoint(inst~>xy transform))
    fprintf(outPort " %d. %s%s %L\n" ctr hierInstPath inst~>cellName dbTransformPoint(inst~>xy transform))
    inst~>master
    dbConcatTransform(inst~>transform transform)
    strcat(hierInstPath inst~>cellName "/")
    ) ;when
    t
    CCFgetInstanceNamesAndCoords(cvId)
    fprintf(outPort " \n\n\n <<<------------------------------------------>>>" )
    fprintf(outPort " \n\n End of instances coordinates list . " )
    fprintf(outPort " \n\n <<<------------------------------------------>>>" )
    close( outPort)
    ;view("./netConnection_layout.txt" list(0:0 500:500) "SCHEMATIC NET CONNECTION")
    ; edit("./netConnection_layout.txt")
    ;hiRegTimer("system("open_net_selected")" 100)
    sleep(3)
    system("gedit ./instance_coord.txt &")
    ; End of outport
    );proc
    Best regards,
    Marben
  • wenckey
    wenckey over 7 years ago in reply to Marben
    THanks a lot~ Very useful
  • wenckey
    Hi, Marben:
    I try to find a specific cellname's hierachy, and I edit the code like this: (add the if to match the cellname)
    if(inst~>cellName=="specificCell" then<-----added
    ctr = ctr +1
    );endif<-------added
    Seems not work.
    Do you have any suggestion?
    Andrew Beckett over 7 years ago in reply to wenckey
    It works for me. Did you get the cell name correct in the comparison?
    I did have to put my peril-sensitive sunglasses on to read the code though!
    • no local variables
    • not sure why the CCFgetInstanceNamesAndCoords was declared within the outer function - unless you were writing this in SKILL++ mode - i.e. with a .ils suffix. Only then would the function be local and see the ctr variable as being lexically scoped.
    • don't know why there's a sleep for 3 seconds at the end - this shouldn't be necessary since you've closed the file.
    • I assume the formatting was lost when the code was pasted here...
    Maybe I'm being a bit harsh ;-)
  • DilipChalla
    DilipChalla over 7 years ago in reply to Andrew Beckett
    I am first time SKILL user , and i am trying to automate a process and I need to get the hierarchy from source to destination . (Source is always from Cell A and destination might change)
    for example : for "a" on Cell A  my expecting output should be like  (InstanceOfCellA.InstanceOfCellB.InstanceOfCellC.InstanceOfCellD) and (InstanceOfCellA.InstanceOfCellB.InstanceOfCellE) ; basically all fan out hierarchies of "a" and dump the outputs  to some text file .
    It should do for all ports going out on Cell A . (like a,b,c till x )
    Please guide me on this or let me know the right reference material to develop code .
    Dilip .
    Andrew Beckett over 7 years ago in reply to DilipChalla
    Hi Dilip,
    This is quite a complex task, and to be honest more than I can really answer here. To handle net tracing through the hierarchy (especially if you have busses/bundles and iterated instances anywhere) is quite complicated - I’ve done it before but the code I have isn’t really fit for sharing as it was written for a specific application many years ago.
    However, I’m wondering whether the probe assistant (Window->Assistants->Probes) will do what you want. Probe the net (e.g. using the 9 bindkey) and then the assistant at the bottom will show everything to which the net is connected. You can then save that to a file from the assistant. So with this, you may not need to write any SKILL code - or can adapt the output to suit your needs?
  • DilipChalla
    Hi Andrew ,
    Thanks for  quick reply . Yeah that would work , but in reality there are at least a hundred or more nets to probe.I just want to find a way to automate it and reuse for different projects .
    I also find another problem here , for example a[0:5] , if CellD uses a[3:5] and cellE uses a[0:2] , we need to trace the hierarchies even if the bus splits .
    Best Regards,
    Dilip.
    Hi Dilip,
    One thought - there's a new function added in IC618/ICADVM181 called schTraceNet which allows you to have a callback to collect information as it traces a net. This might make it easier to implement?
