  3. hdbTraverse.il does not follow the TOP config view fields...
  • Views 16263
iguerra
iguerra over 7 years ago
I am using the hdbTraverse.il example in order to traverse a config view. However it seems that it always traverses the config view based on the "schematic" view and for the same cell to belong the config to. I mean, it waives the TOP library/cell/view fields of the config file.
Example 1: When I try to traverse mylib->mycell_1->config view by setting TOP fields as "mylib", "mycell_1", "schematic_2", the hdbTraverse.il always traverses "myilb", "mycell_1" and "schematic" (instead of schematic_2).
Example 2: When I try to traverse mylib->mycell_1->config view by setting TOP fields as  "mylib", "mycell_2", "schematic", the hdbTraverse.il always traverses "myilb", "mycell_1" (instead of mycell_2) and "schematic".
I have tried to debug a little more on hdbTraverse.il and I have the feeling that the line "hdbCreatePathVector(config)" is the one responsible of waiving the TOP fields, however I am not sure. Could you please provide some feedback about if is possible to traverse a config file by following the TOP config view fields?
Thanks and regards,
Ivick.
    Hi Ivick,
    This sounds a bit odd. It works fine for me - it's picking the correct library and view (I didn't bother testing the cell) - my config is in a different library, and I have two configs, one with schematic and one with schematic2 as the top cell, and both behave correctly when I run either:
    hdbtTraverseConfigStart("" " " "lib1" "top" "config" "Full" "yes" "CDBA")
    hdbtTraverseConfigStart("" " " "lib1" "top" "config2" "Full" "yes" "CDBA")
    The function hdbtTraverseConfig does look up the top lib/cell/view name:
    topLib = hdbGetTopLibName(config)
    topCell = hdbGetTopCellName(config)
    topView = hdbGetTopViewName(config)
    So I don't see why this wouldn't work.
    Which IC subversion are you using? Are you directly using the hdbTraverse.il code from the tools.lnx86/hdb/examples/hdbTraverse.il dir in the installation (the code hasn't changed in a very long time - the code in the final ISR of IC5141 is the same as it is now in IC617 or IC618, but it did change some time during IC5141 - USR6 is the same, but USR1 is different - I don't have the intervening versions lying around).
  • iguerra
    iguerra over 7 years ago in reply to Andrew Beckett
    I agree that the functions hdbGetTopLibName(config),  hdbGetTopCellName(config) and hdbGetTopViewName(config) provide the correct TOP values, however the traverse on the config file is always performed on the non-TOP values (I mean based on the config view lib/cell). Basically the following code is the one is not working on my side:
    hdbtTraverseConfigStart("" "  " libName cellName configName  "Min" "1" "CDBA");
    pathVect = hdbCreatePathVector(config)
    hdbPushPathVect(pathVectStack pathVect)
    rtn = hdbtTraverseView(newIndent step pathVectStack
    topLib topCell topView
    travType doOutput nameSpace)
    Even when the TOP values are being provided as arguments to the hdbtTraverseView procedure, at the end the result of the traverse procedure (rtn) is performed on the config view lib/cell data instead on the TOP lib/cell values of the config view. Please let me know if you think I am missing something.
    Thanks and regards,
    Ivick.
    Andrew Beckett over 7 years ago in reply to iguerra
    Hi Ivick,
    Well, it works for me. I checked again using the same arguments you did ("Min" and "1" as opposed to "Full" and "yes" that I'd used), and it worked fine - in both cases I tried it with it was correctly traversing the lib/cell/view specified as the top cell in the config.
    You didn't answer my earlier questions:
    Maybe you should contact customer support - I can't see anything wrong here and have not come across anyone else reporting a similar issue.
  • iguerra
    My IC subversion is ICADV12.3-64b.500.19 and I am using the code from the examples directory.
    Thanks and best regards,
    Ivick.
    Hi Ivick,
    I cannot explain why (or how) this can behave as you say it does, so the best option would be for you to contact customer support as I suggested earlier. That way an application engineer can take a look at what you're doing and hopefully see and explain what is wrong.
