  3. skill program to fix off grid pin in symbol
  • Views 16330
Nhumai
Nhumai over 7 years ago
HI All,
I have a symbol below. The top pin vpb on the left is off grid. I would like to to move it to the left . I run the program "CCSComposerGridSnap.il" down load from cadence but "CCSComposerGridSnap.il" only move a wire to the right and not moving the pin of the symbol. Do you know if there is any enhanced scripts of "CCSComposerGridSnap.il" to meet my need ?
thanks
Nhumai
  • drdanmc
    drdanmc over 7 years ago
    You could do something like the following (you'll need to fill in some of the details)
    ;; open the symbol cellView, cv = the cellView ID
    ;; iterate over all shapes which are pins
    foreach(fig setof(X cv~>shapes X~>pin)
      cond(
         ( member(fig~>objType list("rect" "ellipse))
            xy = centerBox(fig~>bBox)
        ( ;; code to deal with other shapes
       (t
         error("Unable to handle %L" fig~>objType)
      ) ; ** cond **
      ;; now check that xCoord(xy) and yCoord(xy) are both on-grid and if not, put them on-grid
      ;; and update the figure location.  For a "rect", just find the bounding box width/height and
      ;; compute a new bounding box with the same width/height whose center is on-grid and then
      fig~>bBox = new_box
      ;; for other shapes you may need some other bits of code.
