  3. skill code to instantiate a layout in a master layout c...
  • Subscribers 148
  • Views 16426
skill code to instantiate a layout in a master layout cell
Nhumai
Nhumai over 7 years ago
Hi All,
I try to build a array of my layout but first I want to see if I can instantiate 1 layout in a master layout cell.
I am still new in skill and try to learn as much as I can. I came up with 3 line code below
cv=dbOpenCellViewByType("s279_nl" "uc_array" "layout" "layout" "a")
lib=ddGetObj("s279_nl")
dbCreateParamInstByMasterName(geGetEditCellView() "s279_nl"  "uc_10_19_2018" "layout" "uc"  0:0 "R0"  1)
uc_array is the layout cell I want to put uc_10_19_2018 in it. However, I got the warning  like
*WARNING* (DB-270208): dbOpenCellViewByType: unrecognized database viewType 'layout'
*WARNING* (DB-270210): dbOpenCellViewByType: library 's279_nl' does not exist
*WARNING* (DB-270329): dbCreateParamInstByMasterName: invalid master id detected.
and the 3 lines code above done not thing.
Please let me know how I can fix them.
thanks
Nhumai
  • mbracht
    mbracht over 7 years ago
    HI Nhumai,
    The dbOpenCellViewBtType(..) goes wrong because for one because the library "s279_nl" doesn't exist and other than because you specify an invalid cellViewType "layout" - it must be "maskLayout".
    I assume the non existing library "s279_nl" is also the reason why dbCreateParamInstByMasterName(..) doesn't work - it cannot find the master cell of the instance you try to create.
    I don't see the purpose of the ddGetObj(..) in your code above but it'd be anyway interesting to see it's returns value - it's most likely nil if "s279_nl" does not exist.
