  3. Stopping the Escape key from closing my dialog.
  • Views 17407
KevinWH
KevinWH over 7 years ago
I'm creating a dialog with hiDisplayForm
When the form is displayed, and I press the "Escape" key, the dialog closes.
Is there a way to prevent that behavior?
    Not as far as I know...
  • RK56
    RK56 over 7 years ago in reply to Andrew Beckett
    I wonder why not. What if hiFormCancel is assigned to the Escape key?
    Andrew Beckett over 7 years ago in reply to RK56
    You can't define bindkeys for transient forms (only for Window forms - i.e. forms instantiated into window). So the esc key (when the focus is on the form) will cancel the form as built-in behaviour (so I'm not sure what benefit assigning hiFormCancel() to the escape key would have, since that would be a bindkey for over the canvas in a particular application, and it already cancels the form if the focus is on the form anyway). There is a cdsenv var for options forms (i.e. forms associated with an enter function):
    ui      cancelEnterFunHidesOptionForm boolean t
    which means that esc doesn't cancel but hides the form (on the first press) - the second press does however cancel the command. That's almost certainly not what you wanted though.
