  3. viaGenerateViasAtPoint very slow
  • Views 16640
Manolo Envido
Manolo Envido over 7 years ago
We create a SKILL script to generate a lot of vias with viaGenerateViasAtPoint, everything is working fine but it takes a lot of time (more than 500 different points can take up to 20 minutes).
Doing a quick search in this forum we found this thead form a couple of month ago with a similar problem:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/38456/using-auto-vias-through-skill
They said that the issue is related to checkout and check-in of license each time this functions is executed, so when executed in loop for putting vias, it takes time. It takes check-out/in 12 tokens each time and thus takes time.
Because of that we suspect is this check-out/in of tokens that make the delay. We used to have a very similar problem with viaGenerateViasFromShapes but it was solved by using a list of shapes as a parameter in stead of a loop but viaGenerateViasAtPoint only takes a single point in stead of a list of points.
Replacing this:
    foreach( point ptsList
        viaGenerateViasAtPoint(cvID point myViaOptions)
With this:
        viaGenerateViasAtPoint(cvID ptsList myViaOptions)
Gives an "Invalid point" error.
Is there a workaround? Are we making a mistake in the usage of viaGenerateViasAtPoint? Maybe there is another similar Via Function to use instead we are not aware of?
    Andrew Beckett over 7 years ago in reply to Manolo Envido +1
    This has been fixed in IC617 ISR21 and ICADV123 ISR21 (so that's the .500.21 subversion). When a script or function containing multiple calls to these via functions, the license is checked out at the first…
  • mbracht
    mbracht over 7 years ago
    Hi Manolo,
    Well if you read the cdnshelp documentation for these functions you will find that viaGenerateViasAtPoint(..) expects exactly _one_ specific point as it's second argument as opposed to viaGenerateViasFromShape() which expects a _list_  of shapes...so no I don't think there is a way to achieve this...sorry!
    Max
  • Manolo Envido
    Manolo Envido over 7 years ago in reply to mbracht
    Yes, that is exactly the problem. For what I read is a relatively new function so it could be a nice upgreade.
    But in the mean time maybe there is a way of retaining the tokens while on the loop in stead of check-out/12 each time?
    This has been fixed in IC617 ISR21 and ICADV123 ISR21 (so that's the .500.21 subversion). When a script or function containing multiple calls to these via functions, the license is checked out at the first call, and is returned when the script finishes. This was as a result of CCR 1879723. So I suggest you ensure you're using the latest hotfix of IC617/ICADV123, and that should improve your performance.
  • Manolo Envido
    Manolo Envido over 7 years ago in reply to Andrew Beckett
    Thanks, that's good to know. I'll  confirm if it's fixed after doing the update.
