  3. OCEAN: Accessing device parameters
  • Views 15452
ZoltanT
ZoltanT over 7 years ago
Hi Everyone,
Is it possible to access the device parameter from the netlsit in OCEAN? I would like to plot some curves as a function of the current density. I can get the current easily, but I need a hard coded number in my ocean to normalize the current. This number will be out of date if the schematic changes. Therefore I would like to ask down the transistor width, number of fingers and multiplier values.
Thanks, Zoltan
    Hi Zoltan,
    pv("/I0/M1" "m" ?result 'instance)
    pv("/I0/M1" "w" ?result 'instance)
    pv("/I0/M1" "nf" ?result 'instance)
    Assuming this is (say) a bsim4 device. You can check what parameters are available by doing:
    selectResult('instance)
    dataTypes()
    and then if "bsim4~instance" is one of the types you can then do:
    outputParams("bsim4~instance")
    Note that to get all this, you'd have to have saved the elements inst entry on the Outputs->Save All form.
  • ZoltanT
    ZoltanT over 7 years ago in reply to Andrew Beckett
    Thank you Andrew!
