  3. How to select the specific type of object by coordinati...
  • Replies 10
  • Views 19211
How to select the specific type of object by coordination
wenckey
wenckey over 7 years ago
In a layout cellview, I have the coordinate of the object, but in that location many objects there, like path/ via/ polygon
if I only want to select the type "via", what skill command I can use?
How about select all object in the location?
Also I want to move the selected object to a certain location. What's the command?
  • Marben
    Marben over 7 years ago
    Hi Wenckey
    Something like these.
    Hope this helps.
    procedure( svx()
     cv = geGetEditCellView()
     x = 13.899
     y = 0.37
     foreach(via cv~>vias
      via_x = car(via~>xy)
      via_y = cadr(via~>xy)
      if( via_x == 13.899 && via_y == 0.37 then
       geSelectFig(via)
      ) ;if
     );for
    ) ;proc
    ; To select all object in that location.
    procedure( sva()
     x = 13.899
     y = 0.37
     geSelectAll()
     foreach( obj geGetSelSet()
      x_coord = car(obj~>xy)
      y_coord = cadr(obj~>xy)
      printf("\nx = %L y = %L" x_coord y_coord)
      if( x_coord != x && y_coord != y then
       geDeselectFig(obj)
      ) ;if
     ) ;for
    );proc
    Best regards,
    Marben
    Andrew Beckett over 7 years ago in reply to Marben
    Hi Marben,
    Unfortunately that wouldn’t be very efficient for a large layout with lots of vias and lots of shapes.  Better would be to use dbViaQuery or dbShapeQuery to find vias or other shapes in that location. You’d just define the bBox as a list of the point twice. You could also use dbGetOverlaps as a more general query for objects in that location - in all cases you’d use 0 as the start and stop level, and then you’d use geSelectFigs on the resulting list of objects.
  • wenckey
    wenckey over 7 years ago in reply to Andrew Beckett
    Thanks for the response. Can you give me a quick example like select the via in location(X,Y).
    I cannot find the instruction for dbViaQuery or dbShapeQuery in cdsFinder. How can I find the command in any document?
  • wenckey
    wenckey over 7 years ago in reply to Marben
    Thanks for your response. One problem is my xy is not the via's xy, it may be the center of the via.
    Andrew Beckett over 7 years ago in reply to wenckey
    cv=geGetEditCellView()
    pt=17:-1
    vias=dbViaQuery(cv list(pt pt) 0 0)
    geSelectFigs(vias)
    I'm rather surprised that you don't find dbViaQuery or dbShapeQuery in cdsFinder or by searching for it in cdnshelp. Which IC version are you using? (what does getVersion(t) in the CIW return?)
  • ZoltanT
    ZoltanT over 7 years ago in reply to wenckey
    My naiv intuation says that once you have a subset of vias you can iterate over them and check whether their bBox includes your point.  Somethig like that:
    if( car(bl) < car(point) && car(ur) > car(point) && cadr(bl) < cadr(point) && cadr(ur) > cadr(point) then via_is_over_the_location() )
    bl: bottom left coords
    ur: upper right
    Andrew Beckett over 7 years ago in reply to ZoltanT
    However, as I said in the other branch of this thread, that's not going to be very efficient when you have a million vias (for example). Far better to use the region query functionality that is available as this is designed to rapidly identify objects in a particular region of the layout (this is used all over the place, including to identify which objects in the database should be displayed in the current zoom window, so it has to be very fast). So the dbViaQuery approach I suggested in the other part of the thread would do this much more efficiently.
  • wenckey
    Hi, Andrew:
    Thanks a lot! I checked my cadence version is "sub-version  IC6.1.7-64b.500.11" and I can find it with the help menu.
    My cdsFinder is old, I need to update it!
    Kevin
    Hi Kevin,
    Presumably something is wrong with your search path as it should just find this in the tools/bin dir of the IC installation. You can also just type startFinder() in the CIW to launch it, and that should pick the cdsFinder from your current installation. The current version has a useful "More Info" button which takes you from the quick summary to the full documentation.
    Kind Regards,
  • wenckey
    Got it!~
    That will be great help.
