  3. dc_pivot_check not working within ocean
  • Views 16109
oyayla
oyayla over 7 years ago
I am running spectre simulation using ocean script and getting Bad pivoting during DC analysis. I have added dc_pivot_check as below but it is not accepted by ocean.
option( ?categ 'turboOpts
'numThreads "4"
'mtOption "Manual"
'uniMode "APS"
'dc_pivot_check "yes"
In log file, I am getting below warning:
\o WARNING (OCN-6012): Invalid option: dc_pivot_check. Use ocnDisplay('option) to see the list of options, or
\o use ocnHelp('option). You can also refer to online help on simulator.
I have searched ocean documents but couldn't find how to include the dc_pivot_check. One more thing, when ADEL state is saved as ocean script, the format is same as above.
yayla
    Hi Yayla,
    You didn't mention which IC version (or subversion) you're using (Help->About... will tell you). From a quick check. it seems that dc_pivot_check was added into the ADE user interface in IC616 ISR10 (6.1.6.500.10). Assuming you're using an older version (this version came out over 4 years ago), then you'd have to do:
    option( 'additionalArgs "dc_pivot_check=yes")
    This is the "get out of jail free" card for spectre options not yet supported through the UI - you're using the Additional Arguments field on the Miscellaneous tab of the Simulation->Options->Analog form in ADE to do this.
  • oyayla
    oyayla over 7 years ago in reply to Andrew Beckett
    Thanks for the reply. My IC version is: ICADV12.3-64b.500.18. Also Tool 'cadenceMMSIM' Current project version '16.10.479
    When I use the GUI, I can see the dc_pivot_check option in Simulator Options/Algorithm window btw. That seems to work if I choose that option from GUI though running sim in ocean doesn't recognize.
    yayla
    Andrew Beckett over 7 years ago in reply to oyayla
    Hi Yayla,
    Ah, I just re-read your original post (I read it on my phone initially and missed this important aspect). The issue is that you've lumped in the dc_pivot_check setting with other settings in the turboOpts category. This option is not a turboOpts related option. So instead, call options() twice:
      'numThreads "4"
      'mtOption "Manual"
      'uniMode "APS"
    option('dc_pivot_check "yes")
    Then it will work (with the version you're using, certainly - I checked).
