  3. how to add txt and pin to every layout in a lib
  • Subscribers 148
  • Views 15334
Nhumai
Nhumai over 7 years ago
Hi All,
I have a code below
The procedure addtxt is working fine for each individual cell. Now I want to run for 165 cells in my lib so I added the code on the top (7 lines on the top) but it doesn't work
Please let me know what is wrong ?
lib=ddGetObj("sc12tps_v1_test")
foreach(cell lib~>cells
  when(ddGetObj(lib~>name cell~>name "layout")
    design(lib~>name cell~>name "layout" "a")
    addtxt()
procedure(addtxt()
let(()
  cvId = geGetEditCellView()
  nwShapeL =setof(obj cvId~>shapes rexMatchp("NW" obj~>layerName))
  foreach(shape nwShapeL
     llcoord = car(shape~>bBox)
;     printf("The llcoord is %L\n" llcoord)
;     printf("The xcoord is %L\n" car(llcoord))
;     printf("The ycoord is %L\n" cadr(llcoord))
     xllcoord = car(llcoord) + .04
     yllcoord = cadr(llcoord) +.04
     coord = list(xllcoord yllcoord)
;     printf("The coord is %L\n" coord)
     label = "vpb"
     txtlayer = list("NW" "drawing")
     dbCreateLabel(cvId txtlayer coord label "centerCenter" "R0" "roman" .1)
     xll = xllcoord - .02
     yll = yllcoord - .02
     xur = xllcoord + .02
     yur = yllcoord + .02
     dbCreateRect(cvId list("NW" "drawing") list(xll:yll xur:yur ))
;;;;;Now for subtap
  subShapeL =setof(obj cvId~>shapes rexMatchp("ND" obj~>layerName))
  foreach(shape subShapeL
     label = "vnb"
     txtlayer = list("PW" "drawing")
     dbCreateRect(cvId list("PW" "drawing") list(xll:yll xur:yur ))
thanks
Nhumai
    Hi Nhumai,
    The main issue is that you are calling the design() function in your code at the top, and this is the OCEAN function to specify the design to be used in netlisting/simulation. It does not open the design and certainly does not mean that geGetEditCellView() (which you're calling in the addtxt function) will pick up the design since that returns the cellView open in the current window (and design does not open any window).
    What you should do is replace the call to design as follows:
        cv=dbOpenCellViewByType(lib~>name cell~>name "layout" "maskLayout" "a")
        when(cv
          addtxt(cv)
    and change the top of the addtxt function as follows:
    procedure(addtxt(@optional (cvId geGetEditCellView()))
    let((nwShapeL coord label llcoord xllcoord yllcoord txtlayer xll yll
        xur yur subShapeL)
    Note that since you'd put (as it stood) a rather pointless let() around everything (there's no point using let if you don't specify any local variables), I put all the variables that should have been local into the let. I changed the function to accept an optional argument which is the cellView id, which defaults to the current window so you could still call it with no arguments and have it work on the current window. As you'll see, the revised code at the top passes in the cellView to work ok.
    I'd also advise changing the function name to begin with a prefix which is unique in some way (and begins with a capital letter) to avoid clashing with anyone else's addtxt function that might get created.
  • Nhumai
    Nhumai over 7 years ago in reply to Andrew Beckett
    thanks for detail advises . I follow your instructions  and it working fine now :-)
    thanks
    Nhumai
