  3. RE: SKILL function to output the result from lmstat com...
  • Subscribers 148
  • Views 16761
RE: SKILL function to output the result from lmstat command
rajoli
rajoli over 7 years ago
I am also not able to run lmstat command using ipcBeginProcess.
So, please help me..
I have tried following way. please any one tell me what's wrong in my code.
procedure(Fun()
let((cid data)
cid = ipcBeginProcess("lmstat -a -c 5280@license-01")
ipcWait(cid)
data = ipcReadProcess(cid)
println(data)
);let
);proc
function Fun redefined
Fun
Fun
"sh: /cad/cadence/ICADV12.30.721/tools/bin/lmstat: /lib/ld-lsb.so.3: bad ELF interpreter: No such file or directory\n"
nil
Rajoli
    Hi Rajoli,
    I split this from the original discussion because the Forum Guidelines ask you not to post on the end of old threads (this is a different issue from the earlier thread, plus it's an 8 year old thread).
    I'm guessing that if  you try to run "lmstat" from the command line you get a similar error. It looks from the message that a 32-bit shared library is missing on your machine. The lmstat executable is a 32-bit executable and maybe you only have the 64-bit libraries installed (in /lib64). Perhaps you can check if /lib/ld-lsb.so.3 exists?
    On my (RHEL6.5) machine, this comes from this RPM:
    UNIX> rpm -q -f /lib/ld-lsb.so.3
    redhat-lsb-core-4.0-7.el6.i686
    The similar 64-bit RPM is here, but that won't get used by "lmstat"
    UNIX> rpm -q -f /lib64/ld-lsb-x86-64.so.3
    redhat-lsb-core-4.0-7.el6.x86_64
    UNIX> which lmstat
    /export/home/apps/IC617_isr/tools/bin/lmstat
    UNIX> file /export/home/apps/IC617_isr/tools/bin/lmstat
    /export/home/apps/IC617_isr/tools/bin/lmstat: symbolic link to `lmutil'
    UNIX> file /export/home/apps/IC617_isr/tools/bin/lmutil
    /export/home/apps/IC617_isr/tools/bin/lmutil: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, stripped
    UNIX> ldd /export/home/apps/IC617_isr/tools/bin/lmstat
    linux-gate.so.1 => (0x00d8d000)
    libpthread.so.0 => /lib/libpthread.so.0 (0x00b4e000)
    libm.so.6 => /lib/libm.so.6 (0x00b1b000)
    libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00b6b000)
    libc.so.6 => /lib/libc.so.6 (0x00982000)
    libdl.so.2 => /lib/libdl.so.2 (0x00b47000)
    /lib/ld-lsb.so.3 => /lib/ld-linux.so.2 (0x00960000)
    So you probably need to install the missing package.
  • rajoli
    rajoli over 7 years ago in reply to Andrew Beckett
    I tried same way but now i got different error.
    Error:
    "lmstat - Copyright (c) 1989-2018 Flexera. All Rights Reserved.\nFlexible License Manager status on Tue 12/4/2018 20:42\n\nLicense server status: 5280@license-01\n License file(s) on license-01: /u/site/license/cadence_vm.dat:\n\nlicense-01
    Rajoli
    Andrew Beckett over 7 years ago in reply to rajoli
    Hi Rajoli,
    That's not an error. You're only reading the first string that comes back - there's no guarantee that there will only be a single string coming back from the child process. If you do this, you should get everything:
    procedure(Fun()
    let((cid data)
      ipcWait(cid)
      printf("%s" data)
      while(data
        data = ipcReadProcess(cid 10)
        when(data
          printf("%s" data)
    );let
    );proc
