  3. How to make all schematics in the library not editable using...
  • Views 16531
How to make all schematics in the library not editable using SKILL ?
Marben
Marben over 7 years ago
Hi All,
We have a working library with layout engineers
working in, where one of our layout engineer edited the
schematics without permission. Our group have lot of trouble in this.
I want to have a SKILL code to make all schematic in the library
not editable, so that original schematic will not be edited by accident.
How can it be done using SKILL ?
Please help.
Best regards,
Marben
  • Quek
    Quek over 7 years ago
    Hi Marben
    Maybe it would be good for you to first provide some info on the following:
    a. Are you using any version management software (e.g. DesignSync, ICmanage, etc)? If yes, do you mean that the layout engineer checked out the schematic, edited it and then check in the schematic?
    b. Do the schematic and layout engineers share the same linux account?
    Best regards
    Quek
  • Marben
    Marben over 7 years ago in reply to Quek
    Hi Quek,
    Answer : No, I'm not using any version management software (e.g. DesignSync, ICmanage, etc).
    Answer: Yes, the schematic and layout engineers share the same linux account.
    Best regards,
    Marben
  • Quek
    Quek over 7 years ago in reply to Marben
    Hi Marben
    I have heard about such scenarios. Unfortunately, this cannot be easily resolved because of the account sharing. I think a possible but not so effective implementation can be as follows:
    a. All layout engineers must have "setenv layoutDesigner yes" in their .cshrc file
    b. Use the following SKILL procedure:
    procedure( CCSsetSchAsReadOnly(args)
       let( ()
          when( getShellEnvVar("layoutDesigner")=="yes"
             printf("Setting schematic cell %s to read-only for layout designers\n" args->cellName)
             dbReopen(geGetWindowCellView() "r")
             ; Add more codes to disable "File->Make editable", etc
          ) ;when
       ) ;let
    ) ;procedure
    deRegUserTriggers("schematic" nil nil 'CCSsetSchAsReadOnly)
    deRegUserTriggers("schematicXL" nil nil 'CCSsetSchAsReadOnly)
    Using separate linux accounts is the best solution. All the best for 2019. : )
    Best regards
    Quek
  • Marben
    Hi Quek,
    Thank you very much for your code.
    Yes, I think so, using separate linux accounts is the best solution,
    and making a backup pf the whole library.
    Best regards,
    Marben
