  3. Problem with execute skill procedure do convert "<>" to...
  • Subscribers 150
  • Views 1114
Problem with execute skill procedure do convert "<>" to "[]"
zgzg8312
zgzg8312 over 7 years ago
Hi,Guys!
    I write a skill procedure do convert "<>" to "[]" or "[]" to "<>",like below.
    When I execute convert("a[1]"),it work ok,result "a<1>",but I execute convert("a<1>"),it not work,result nil !!
    Where is the problem?
    procedure(convert(label)
                      if(label==car(parseString(label "[]"))
                                  then
                                         a_label=car(parseString(label "<>"))
                                         b_label=car(cdr(parseString(label "<>")))
                                         strcat(a_label "[" b_label "]")
                      else nil
                      if(label==car(parseString(label "<>"))
                                  then
                                         a_label=car(parseString(label "[]"))
                                         b_label=car(cdr(parseString(label "[]")))
                                         strcat(a_label "<" b_label ">")
                        else nil
Best regards!!!!
  • mschw
    mschw over 7 years ago
    a SKILL procedures return value is always the last SKILL expression in the procedure body. The last SKILL expression in your procedure is the second if statement. If you execute convert("a[1]"), the second if statement returns the last SKILL expression in the true branch, which is strcat(a_label "<" b_label ">"). If you execute convert("a<1>") the second if statement returns the last SKILL expression in the false branch, which is nil. To overcome the problem you can save the return value in a variable and add this return value as last SKILL expression in the procedures body. e.g.
    (let (a_label b_label returnValue)
    if(label==car(parseString(label "[]")) then
    returnValue = strcat(a_label "[" b_label "]")
    else
             nil
    if(label==car(parseString(label "<>")) then
    returnValue = strcat(a_label "<" b_label ">")
    else
              nil
                       returnValue
    I also added a let statement for the local variables.
    Kind regards,
    Matthias
  • zgzg8312
    zgzg8312 over 7 years ago in reply to mschw
    Understand !!! Thanks a lot !!!
