  3. Unable to run an ocean script after receiving the message...
  • Views 16006
Unable to run an ocean script after receiving the message *WARNING* (infile): not a normal file
LuisGutierrez
LuisGutierrez over 7 years ago
I'm using Virtuoso IC6.1.7-64b.500.21 and the output of spectre -W is sub-version  18.1.0.143.isr1. I'm running some simulations via ocean scripts and sometimes, if there's a bug in the script the simulation will fail (of course). However, after correcting the error and trying to run the script again, I receive a message in the CIW saying:
And nothing happens. From that moment on I can't run any ocean script and I keep receiving the same message over and over again. The only "work around" is to close and reopen a virtuoso session.Is there a way to recover from such message without having to restart a session?
    This is a bit odd. I've found only a single (rather old) report of this happening with a tmpfs filesystem (and we couldn't reproduce it). As far as I can see, SKILL issues this message if the file is not one of three types (from the fstat man page):
    regular file
    character device
    FIFO
    Can you check what the UNIX "stat" command reports on this file (the one reported in the warning):
    /usr/bin/stat /path/to/your/file
