  3. Set Library source to ddHiCreateCellComboField.
  • Views 17929
iguerra
iguerra over 7 years ago
Could you please show me the way I can set the library source in order to ddHiCreateCellComboField fills with the cell names accordingly?
Also I have the same question but for ddHiCreateViewComboField in order to fill according to a given cell name.
Thanks and regards,
Ivick.
    Hi Ivick,
    The trick is to use ddHiLinkFields. See this little example I just put together:
    /* abLibCellViewComboExample.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 12, 2019
    Modified
    By
    Example of using the enhanced lib/cell/view combo fields that support
    type-in completion.
    Simply call abLibCellViewComboExample() to create and display the form.
    SCCS Info: @(#) abLibCellViewComboExample.il 01/12/19.09:31:51 1.2
    procedure(abLibCellViewComboExample()
        let((grid lib cell view libLabel cellLabel viewLabel
                browse form)
            libLabel=hiCreateLabel(
                ?name 'libLabel ?labelText "Library"
                ?justification 'right
            cellLabel=hiCreateLabel(
                ?name 'cellLabel ?labelText "Cell"
            viewLabel=hiCreateLabel(
                ?name 'viewLabel ?labelText "View"
            lib=ddHiCreateLibraryComboField(
                ?name 'lib ?callback "(ddsUpdateSyncWithForm)"
            cell=ddHiCreateCellComboField(
                ?name 'cell ?callback "(ddsUpdateSyncWithForm)"
            view=ddHiCreateViewComboField(
                ?name 'view ?callback "(ddsUpdateSyncWithForm)"
            browse=hiCreateFormButton(
                ?name 'browse
                ?buttonText "Browse..."
                ?callback "(ddsSyncWithForm (hiGetCurrentForm) 'browse 'lib 'cell 'view)"
            grid=hiCreateGridLayout(
                'grid
                ?items list(
                    list( libLabel 'row 0 'col 0)
                    list( cellLabel 'row 1 'col 0)
                    list( viewLabel 'row 2 'col 0)
                    list( lib 'row 0 'col 1)
                    list( cell 'row 1 'col 1)
                    list( view 'row 2 'col 1)
                    list( browse 'row 0 'col 2)
                    list( 'col_stretch 0 0)
                    list( 'col_stretch 1 1)
                    list( 'col_stretch 2 0)
            form=hiCreateLayoutForm(
                'abImportParasiticsForm
                "Lib Cell View Example"
                grid
                ?sizePolicy 'horizontalExpanding
            ; Need to both instantiate the form and link the fields so that
            ; the combo-boxes use the other fields to inform the choices
            hiInstantiateForm(form)
            ddHiLinkFields(
                form->lib
                form->cell
                form->view
            hiDisplayForm(form)
    [Note: there is a newer version of this code in this post which is a more flexible general lib/cell/view browser but shows embedding of the grid layout in a vertical box layout)
  • iguerra
    iguerra over 7 years ago in reply to Andrew Beckett
    Until now I had the opportunity to apply your suggestion and it worked!
    Thanks and regards,
    Ivick Guerra.
