  3. Assura DRC and RCX batch run with SKILL
  • Subscribers 150
  • Views 17654
henriqueiesam
henriqueiesam over 7 years ago
Hi everyone,
Can somebody please explain me:
1) How to start Assura LVS and RCX with a SKILL script?
2) With the script above. How to get some values (sca, scb and scc) of the extracted view?
This will be done with one simple transistor, but for many sizes and one at a time.
  • Quek
    Quek over 7 years ago
    Hi henriqueiesam
    You can refer to COS article 11803100 for a sample SKILL which can execute Assura DRC, LVS and QRC extraction. Instance parameter values can generally be obtained as follows:
    a. Open the extracted view
    b. Select any instance
    c. Execute the following in CIW:
    cv=geGetWindowCellView()
    inst=css()
    inst~>sca
    You have to use a foreach loop to automate the process. E.g.
    foreach( inst setof(x cv~>instances pcreMatchp("mos" x~>cellName))
       printf("inst: %s sca: %L\n" inst~>name inst~>sca)
    ) ;foreach
    Best regards
    Quek
  • henriqueiesam
    henriqueiesam over 7 years ago in reply to Quek
    Hi Quek, when the SKILL script is executed, I get the following error:
    Removing all existing files/directories in run dir ./autoPVS
    Found gds layer mapping file /***/***/***/***.layermap
    Jan 17 11:22:14 2019: Exporting cdl netlist for cell pmos_test
    Jan 17 11:22:16 2019: Exporting gds file for cell pmos_test
    Jan 17 11:22:18 2019: => Running PVS lvs for cell pmos_test: Unsuccessful
    *Error* fprintf: argument #1 should be an I/O port (type template = "ptg") - nil
    Thanks for the reply.
    Best regards
    henriqueiesam
  • Quek
    Quek over 7 years ago in reply to henriqueiesam
    Hi henriqueiesam
    It looks like my script was only meant for PVS-QTS flow and not Assura-QTS flow. Sorry that I had remembered wrongly. Hope that it is still a good starting point for you to modify it for Assura-QTS flow.
    Best regards
    Quek
  • henriqueiesam
    Hi Quek,
    Ok no problem. For sure it is a good starting point.
    Thanks a lot !!!
    Best regards
    henriqueiesam
