  3. attribute inside cellview
  • Subscribers 150
  • Views 16398
mantang
mantang over 7 years ago
Hi
Is there any document to describe attributes of cellview, figures, pin, ... ?
For example, cellviewType (maskLayout) has attribute of superMaster and master. I want find out the meaning of these attributes.
procedure(CCSexpandView(cellview)
  case(cellview~>cellViewType
    ;; if given a symbol, try to open the schematic for it, or
    ;; return the symbol dbId if "schematic" or "cmos.sch" views
    ;; do not exist
    ("schematicSymbol"
      dbOpenCellViewByType(         cellview~>libName
        cellview~>cellName
        ;; this is the switch view list for schematics
     list("schematic" "cmos.sch" "symbol")
    ;; if given a layout, it is its own master cellview
    ("maskLayout" if(cellview~>superMaster then cellview~>master else cellview))
    ;; for anything else including nil, return nil
    (t nil)
  ); case
); procedure CCSexpandView
MC
    Yes. This is covered in the Virtuoso Design Environment SKILL Reference manual, which you can find using <ICinstDir>/tools/bin/cdnshelp or using the Help menu in Virtuoso. Or you can simply look at <ICinstDir>/doc/skdfref/skdfref.pdf
  • mantang
    mantang over 7 years ago in reply to Andrew Beckett
    Thank you.
    ManChak
  • tmaness
    tmaness over 7 years ago
    To find out the list of database attributes associated to a database object, type the following in the CIW
    dbId~>?
    To list all the attributes and their values associated to a database object, type the following,
    dbId~>??
    This applies to any database object (db:*)
