  3. To know whether LEF Pins location moved or not
  • Subscribers 150
  • Views 16114
Bala Sowjanya
Bala Sowjanya over 7 years ago
In top level of layout LEF pins are there right. We already fixed those & I want to know whether each PIN is aligned correctly or not same as in previous LEF.
Can you tell me how to develop the program for this one
Thanks & Regards,
Bala
  • Quek
    Quek over 7 years ago
    Hi Bala
    Do you mean that you would like to check the positions of macro pins in LEF file against the original layouts?
    Best regards
    Quek
  • Bala Sowjanya
    Bala Sowjanya over 7 years ago in reply to Quek
    Yes
  • Quek
    Quek over 7 years ago in reply to Bala Sowjanya
    Hi Bala
    I think you can use the SKILL script in COS article 20470090. It compares the LEF pins against labels in labels in a gds file. You just need to export the layout as gds.
    Best regards
    Quek
  • Bala Sowjanya
    Is It not possible in program?
  • Quek
    Hi Bala
    No, the program Virtuoso does not has such a built-in check. SKILL is the language of Virtuoso and can be easily used to implement many different kinds of check.
    Best regards
    Quek
