  3. Accessing child instances of schematic instances in Vir...
  • Views 18033
Accessing child instances of schematic instances in Virtuoso
MatthewLove
MatthewLove over 7 years ago
I can use dbFindAnyInstByName to access database objects in Virtuoso's schematic editor.
If the instance has instances within it, do you know how I can access their database objects too?
I can't seem to descend through the hierarchy, or so to speak.
  • mbracht
    mbracht over 7 years ago in reply to MatthewLove +1
    oops - I missed that this is a schematic. Well then you need to go like this: symbolMaster = dbFindAnyInstByName((geGetWindowCellView),<instName>)~>master schMaster = dbOpenCellViewByType(symbolMaster…
    Andrew Beckett over 7 years ago in reply to mbracht +1
    A few additions to what Max said. The viewNameList env var is just what the schematic editor uses by default when you descend edit (unless a config is used), but what is most suitable as your switch…
  • mbracht
    Well once you have the instance returned by dbFindAnyInstByName(..) you can get at its master cell using the master attribute
    masterCv = dbFindAnyInstByName((geGetWindowCellView),<instName>)~>master
    So now you can use again the '~>' operator to get at all cellView aatributes (and user defined properties) in tehy master cell, for example masterCv~>instances
  • MatthewLove
    MatthewLove over 7 years ago in reply to mbracht
    Thanks for the reply.
    I did try that but the instances attribute is nil despite the instance containing a number of sub-instances.
    It seems to be accessing the instance symbol rather than the symbol itself as the master contains the following info:
    cell dd:0x225900f8 cellViewType "schematicSymbol" cellType "none"
  • mbracht
    schMaster = dbOpenCellViewByType(symbolMaster~>libName symbolMaster~>cellName <schematicViewName>)
    ...which in turn raises the question how do you get at the name of the corresponding schematic. Well it depends, if you have a config view defined you need to get the information from there, if not the view list (which you can see in the Editor Options) is available in a SKILL variable by the name of viewNameList:
    (envGetVal "schematic" "viewNameList" )
    Max
    • The viewNameList env var is just what the schematic editor uses by default when you descend edit (unless a config is used), but what is most suitable as your switch list will depend on the application (each netlister typically has its own switch view list, for example).
    • You may also find dbGetAnyInstSwitchMaster useful to find the view to switch into
    • If you need to traverse using a config (which is reasonably complicated, to be honest), you may find <ICinstDir>/tools/hdb/examples/hdbTraverse.il a useful starting point
  • MatthewLove
    Ah right, thanks for the solution!
